Dev Call Feb 18 2019 2300 UTC
Plane
Release Update
Copter
Rover
Attendee count (max): 23
UTC2302 - https://github.com/ArduPilot/ardupilot/pull/10549
  • Speak now or report a bug later!
    • Merged!
  • Interesting to see how Rover is calling lots of stuff on the flightmode class; do like we do in Copter?
UTC2308 - new HAL CPU class
  • Some of this has been merged
    • Removal of the EKF dependency looking for class 150
  • F7s have twice the dmips (performance)
    • Also double-precision
    • Adding fourth compasses / IMUs etc etc sounds like a good idea!
      • How do we identify CPUs that can do that?
        • Add in a class-200?
  • We’re doing opt-in for features
    • Perhaps that’s a better solution
  • HAL_CPU_CLASS is probably dead after the already-merged stuff, unless we add a new CPU class
  • Statustexts pending is large on a cpu class
    • Make this larger on all boards?
    • Lots of memory ATM
  • Memory layout on H7 is working
    • 1MB!
    • [10:13 AM] (Channel) MdB: so more status texts everywhere is better :stuck_out_tongue:
    • [10:13 AM] To Weekly devcall: I’m quoting you on that @MdB
    • [10:13 AM] To Weekly devcall: Out of context.
    • [10:13 AM] (Channel) MdB: CONTEXT PETER!
    • [10:13 AM] (Channel) MdB: CONTEXT REQUIRED!
    • [10:13 AM] To Weekly devcall: :stuck_out_tongue:
    • [10:14 AM] (Channel) MdB: _status_capacity should probably be scaled vs port baud rate rather then fixed size as well… After a certain point super stale statustext is actually more damaging…
  • RPi tends to use up a lot of CPU on IO - e.g. SPI
    • H7 doesn’t use much at all due to use of interrupts
    • Io is very fast on stm32
    • Probably do faster loop rates on H7 vs Pi
  • Memory vs cpu limits
  • 312K is smallest we support on an F7
  • Largest is 512k
  • #ifdef based on RAM size
  • [10:16 AM] (Channel) buzz_mobile: you know the raspi can be run in bare-metal mode yes? (no linux)
  • [10:16 AM] To Weekly devcall: @buzz someone ported ArduPilot directly to the hardware?!
  • [10:16 AM] (Channel) TP: perhaps one core is ArduPilot, rest of cores is Raspian
  • [10:16 AM] (Channel) TP: ?
  • [10:16 AM] (Channel) buzz_mobile: …no but I think u just volunteered…
  • [10:16 AM] (Channel) MdB: buzz: congrats!
  • [10:17 AM] (Channel) MdB: /me selectively read that as buzz volunteering :smiley:
  • [10:17 AM] To Weekly devcall: /me is assuming that was Tom volunteering, since he has a scheme.
  • Tom is tempted to kill this new CPU class
    • Tridge points out that it gives you a central point to change stuff
    • You could use hwdef to do that
    • Closed!
UTC2310 - set home changes
UTC2328 - rejecting set-params based on component id
  • Will this break GCSs attempting to send to stuff
  • Apparently people do use the camera component id
  • Randy: Our component id or broadcast should be the ones we accept
  • Mavlink spec seems to say you should
  • [10:30 AM] (Channel) Michael_duBreuil: I can actually tell you I send to camera per the spec…
    • Even if it hasn’t sent a heartbeat
    • Hard-coded component ID
  • Don’t want to inadvertently set parameters where
  • COMPID_ENFORCE?
  • Make SYSID_ENFORCE a bitmask?
  • There are parameters on cameras
  • CAN stuff should be registered in routing
    • [10:29 AM] (Channel) edwin.hayes: The issue is that the things which talk on different cIDs tend to not also send heartbeats, which is required if you want the routing rules to behave as expected.
    • [10:30 AM] (Channel) MdB: that is a bold protocol assumption…
    • [10:30 AM] (Channel) MdB: I can actually tell you I send to camera per the spec…
    • [10:30 AM] (Channel) MdB: regardless of heartbeats…
    • [10:30 AM] (Channel) edwin.hayes: Correct; and we definitely do this.
    • [10:31 AM] (Channel) buzz_mobile: route or drop.
    • [10:31 AM] (Channel) TP: PWNd
    • [10:34 AM] (Channel) MdB: (I don’t do camera params so I’m fine)
    • [10:35 AM] (Channel) edwin.hayes: This issue also used to cause companion computer to reboot the flight controller, so it’s definitely an issue which needs to be addressed.
    • [10:35 AM] (Channel) edwin.hayes: Not parameter related, but same issue.
    • [10:35 AM] (Channel) Kamal: https://github.com/ArduPilot/ardupilot/blob/6dbe6629412a49dcb0830e2d26f626c62ac1bd1d/libraries/AP_Mount/AP_Mount_SToRM32.h#L51
    • [10:36 AM] MarkW moved in from Ardupilot mumble by the server.
    • [10:36 AM] (Channel) MdB: some stuff like the reboot I’d maybe always force the ID to be correct
    • [10:37 AM] (Channel) MdB: I’d argue reboot/arm/disarm should always be forced to match
    • [10:37 AM] (Channel) edwin.hayes: Presumably other ‘DO’ commands would also be accepted without being the right device.
    • [10:37 AM] (Channel) buzz_mobile: it’s better to be more strict and give a decent warning message than to continue to be liberal without any user notification.
    • [10:38 AM] (Channel) edwin.hayes: Arming, disarming, etc.
    • [10:38 AM] (Channel) buzz_mobile: I think we should break that, sorry.
    • [10:38 AM] (Channel) Michael_duBreuil: ha no I can’t :smiley:
    • [10:38 AM] (Channel) Michael_duBreuil: that has shipped units
    • [10:38 AM] (Channel) Michael_duBreuil: and I think I’m correct…
    • [10:39 AM] (Channel) Michael_duBreuil: we are a camera (sometimes)…
  • Have to preserve existing behaviour
  • Special cases for arm/disarm
UTC1139 - https://github.com/ArduPilot/ardupilot/pull/10523
  • G_Dt may not be calculated or used in the best way possible
  • When scheduling is off you can stuff up your integrators and D-terms
    • And will apply it to data which is itself suspect
  • Missing loops would be bad in Plane ATM
    • Position could be off by a bit
  • [10:45 AM] (Channel) MdB: can’t some stuff (such as DCM) just call the scheduler directly rather then try and resolve G_Dt to be globally/best?
    • [10:42 AM] (Channel) MdB: plane primarily uses it for quadplane stuff… Consitency with copter seems valubale there though…
    • [10:42 AM] (Channel) buzz_mobile: it’s bringing the platforms closer together… maybe save fixing outliers for later.
    • [10:43 AM] (Channel) buzz_mobile: …or keep two timestamps.
    • [10:45 AM] (Channel) MdB: can’t some stuff (such as DCM) just call the scheduler directly rather then try and resolve G_Dt to be globaly/best?
    • [10:45 AM] (Channel) edwin.hayes: Wouldn’t a better solution be to just reject the integrator updates where the timestamp is too long for the assumption of constant [acceleration] across the sample period?
    • [10:45 AM] (Channel) MdB: we do do that edwin at some point
    • [10:45 AM] (Channel) MdB: At least on some of the controllers, maybe not all of them though
    • [10:46 AM] (Channel) edwin.hayes: Ok cool. Seems like a prudent thing to be doing.
    • [10:47 AM] (Channel) MdB: agreed
    • [10:47 AM] (Channel) RandyMackay: https://github.com/ArduPilot/ardupilot/commit/f06fdf330efaf8edb5c92374fd24cc328651e501
    • [10:47 AM] (Channel) MdB: Scheduler should maybe retain the smoothing internally for you, but yeah I support fetching
    • [10:47 AM] (Channel) MdB: https://github.com/ArduPilot/ardupilot/pull/7223/commits
  • Needs more investigation
  • Closed
    • Maybe Sub should get the same as Copter, ‘though?
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/10521
  • We should probably reject a request to stream a mavlink2 message out a malink1
  • We will stop advertising mavlink1 links as mavlink2
  • Old SiK radios
  • Copter will have a behaviour change
    • Won’t set bit
    • Copter can do terrain following with either terrain OR rangefinder
  • Issue on Copter 3.6 with boards that don’t allow terrain without an SD card
  • Can go in in when it’s rebased!
UTC1108 - https://github.com/ArduPilot/ardupilot/pull/10513
  • Does it make things larger?
    • Peter to check
  • Can go in once it’s rebased
UTC1111 - https://github.com/ArduPilot/ardupilot/pull/10499
  • Are people generally happy with this?
  • Apparently!
  • [11:13 AM] (Channel) Michael_duBreuil: do we always have frsky/devo objects allocated?
  • [11:13 AM] (Channel) Michael_duBreuil: I’m thinking this says yes…
  • [11:13 AM] To Weekly devcall: @MdB vehicle configuration #defines ATM
  • [11:14 AM] Unmuted.
  • [11:14 AM] (Channel) Michael_duBreuil: aww the memory usage!
  • [11:14 AM] (Channel) Michael_duBreuil: ideally if init doesn’t find anything we delete the object…
UTC1113 - https://github.com/ArduPilot/ardupilot/pull/10497
  • [11:15 AM] (Channel) Michael_duBreuil: is this faster/is the compiler not essentially doing this?
  • [11:16 AM] (Channel) Michael_duBreuil: … need LTO… these should be the same with proper optimizer :stuck_out_tongue:
  • merged!
UTC1117 - https://github.com/ArduPilot/ardupilot/pull/10477/files
  • Need to make sure _resend_uart handles signing and mavlink1 vs mavlink2
  • Pymavlink can force malvink1 or mavlink2
  • Combine with testing for signing
  • _resend_uart doesn’t fix the sequence number!
UTC1122 - https://github.com/ArduPilot/ardupilot/pull/10472
  • Peter to get this in today
UTC1126 - https://github.com/ArduPilot/ardupilot/pull/8590
  • The 2D vs 3D thing should be reverted
    • [11:34 AM] To Weekly devcall: @MdB I got scope creeped on this one on a devcall, and look where that got me :stuck_out_tongue:
    • [11:34 AM] (Channel) MdB: A great test case!
    • [11:34 AM] (Channel) MdB: For autotest!
    • [11:34 AM] (Channel) MdB: So totally worth it
  • Randy is planning on removing the fallback to DCM in Rover
    • Velocity estimate errors cause DCM to go insane
    • Copter can be flown on DCM
      • Tridge has done so recently with SkyViper
    • Testing DCM: Set an auto mission and set ekf-type-0 and see what happens
  • Maybe add an option bit to disable fallback to DCM?
  • Dcm-vs-ekf is one of the first tests tridge does when looking at a log
  • Closed this PR - add patches to Rover to fix things rather than hacking DCM
UTC1135 - https://github.com/ArduPilot/ardupilot/issues/10465
  • Peter to look at today
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/10399
  • Tridge to look at
  • There is a behaviour change
  • Concern is lower-limit-start-ms being reset
    • Forces us out of relax
UTC1149 - https://github.com/ArduPilot/ardupilot/pull/10378
  • Precision landing for quadplane
  • Autotests should be straight forward!
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/10361
  • Real vehicle tests required
  • Moved to NeedsTesting
UTC0051 - https://github.com/ArduPilot/ardupilot/pull/10290
  • Universal emergency stop
  • Should_estop looks good
  • This looks good
  • Should look at the Copter duplicate-state problem once it has gone in
UTC0056 - https://github.com/ArduPilot/ardupilot/pull/10021
  • Stale
  • MdB to look at
UTC0057 - https://github.com/ArduPilot/ardupilot/pull/9506
  • MdB needs to look at new commits
UTC0058 - https://github.com/ArduPilot/ardupilot/pull/9506/file
  • Parachute / sink rate
  • This will apply to Copter as well
  • Needs some rework on commit comments
  • Parameters that aren’t used should be marked as unused
  • … but would be better to have them work on Copter!
  • Tridge has added comment to PR to help with git
UTC0103 - https://github.com/ArduPilot/ardupilot/pull/6912
  • Stale
UTC0104 - https://github.com/ArduPilot/pymavlink/pull/241
  • Tridge wants a unit test for this
UTC0106 - Copter and Randy
  • https://github.com/ArduPilot/ardupilot/issues/9498
  • Copter can lean past angle max
    • Randy can fix this
  • Matek405 wing std or wing boards don’t boot
    • Notify 199 doesn’t boot
    • External compass causes failures
    • Specific compass
    • Three users have reported
    • Tridge has put board on desk in front of him to try to remind him
  • Zubax won’t initialise when using ChibiOS when using battery
    • But works under USB
  • 3.6.6 Out with a bunch of fixes (see release notes)
  • No specific plans for 3.6.7 at this point for Copter
UTC0110 - https://github.com/ArduPilot/pymavlink/pull/248
  • Required by upstream mavlink?
  • Tridge has wanted for a while
  • Needs to be tested under ArduPilot
  • Should generate exactly the same headers with and without this patch
  • [12:11 PM] (Channel) MdB: We don’t just recurse to accumulate includes? oO
  • Could remove include from ardupilot xml for adsb otherwise XML will be included twice
    • Maybe have a set of files that have been included
UTC014 - Randy and Rover
  • Rover 3.5 is out
  • 3.5.1 out
  • Including BalanceBot in auto mode
  • An do object avoidance in ROS on master
    • Will drive around avoiding obstacles
    • Want to integrate it better to GCS
    • Help would be nice!
  • Hopefully an Antenna release in next little while
UTC0015 - Plane and tridge
  • No real news
  • Pending release but hasn’t gone out yet
UTC0016 - Randy and Funding Committee
  • Concern about partner renewals
    • Running behind
    • Committee is getting back on top of the problem
  • Tridge is chasing SPI on getting payments out for contribution of the month etc
