This is a list of issues discovered during Copter-4.0 testing:
Common supportā¦ problems:
- [ ] users can't figure out which barometer is being used ([discussion](https://discuss.ardupilot.org/t/external-baro-sensor-on-can/51390/6))
- [ ] users can't figure out if Oneshot or DShot are working ([discussion](https://discuss.ardupilot.org/t/oneshot125-42-blhelis/51462), [wiki issue](https://github.com/ArduPilot/ardupilot_wiki/issues/2474), [discussion2](https://discuss.ardupilot.org/t/pixhawk-4-holybro-arducopter-3-6-9-4-0-1rc3-no-control-over-two-motors-in-an-x8-with-dshot/51480), [possible improvement](https://github.com/ArduPilot/ardupilot/pull/13409))
- [ ] two reports of barometer glitches on CubeOrange ([discussion](https://discuss.ardupilot.org/t/barometer-glitch-inducing-ekf-primary-change/51345)), one report on Pixhawk-2.4.8 ([discussion](https://discuss.ardupilot.org/t/copter-instantly-released-itself-from-30m/53368))
Regressions from 3.6.x:
- [ ] autotune method for testing gains has changed ([discussion](https://discuss.ardupilot.org/t/has-there-been-a-change-to-autotune-procedure/51058))
- [ ] logging is skipping messages ([issue](https://github.com/ArduPilot/ardupilot/issues/13810))
- [ ] performance regressions which lead to more long loops ([timings](http://uav.tridgell.net/tmp/perf_regression.txt))
- [ ] speedybee telem5 not working? ([discussion](https://discuss.ardupilot.org/t/speedybee-f4-aio-board/50907))
- [ ] sparky2 doesn't work with UAVCAN? ([discussion](https://discuss.ardupilot.org/t/no-uavcan-communication/50858))
- [ ] kakutef7 not working with px4flow sensor ([discussion](https://discuss.ardupilot.org/t/kakute-f7-mini-and-kakute-f7-aio-px4flow-not-working-in-copter-4-0/51000), [issue](https://github.com/ArduPilot/ardupilot/issues/10105))
- [ ] DCM yaw inconsistent pre-arm message ([discussion](https://discuss.ardupilot.org/t/dcm-yaw-inconsistent-by-68-deg-after-battery-change/50813/22), [discussion2](https://discuss.ardupilot.org/t/ekf2-yaw-inconsistent/51701), [PR](https://github.com/ArduPilot/ardupilot/pull/14334))
New for 4.0.4:
- [x] PreArm failure if UAVCAN compass removed ([issue](https://github.com/ArduPilot/ardupilot/issues/14686))
- [x] LIS3MDL missing ([PR](https://github.com/ArduPilot/ardupilot/pull/14649))
- [ ] NeoPixel causes EKF instability ([discussion](https://discuss.ardupilot.org/t/copter-4-0-4-rc2-available-for-beta-testing/57916/2))
- [ ] CubePurple has no heater but still has BRD_IMU_TARGTEMP param ([discussion](https://discuss.ardupilot.org/t/copter-4-0-4-rc1-released-for-beta-testing/57203/64))
- [x] Compass ordering issue found by HenryW, AndyP (i.e. "unstable sort" of unused compass offsets) ([possible fix](https://github.com/ArduPilot/ardupilot/pull/14529))
- [x] AP_Proximity ignore zones incorrect ([PR with fix](https://github.com/ArduPilot/ardupilot/pull/14496))
Other issues:
- [ ] MAVFTP with MP locks up creating or deleting new folders ([AP issue](https://github.com/ArduPilot/ardupilot/issues/14643), [MP issue](https://github.com/ArduPilot/MissionPlanner/issues/2413))
- [ ] watchdog reset on Copter-4.0.3 ([issue](https://github.com/ArduPilot/ardupilot/issues/14582))
- [ ] DShot on KakuteF7 ([issue](https://github.com/ArduPilot/ardupilot/issues/14475))
- [ ] param download stuck using MP is lua scripts enabled on CubeBlack ([discussion](https://discuss.ardupilot.org/t/activated-lua-scripting-parameter-download-problems/55830))
- [ ] MAVFTP still locking up? ([issue](https://github.com/ArduPilot/ardupilot/issues/13085))
- [ ] Watchdog reset not creating log files ([issue](https://github.com/ArduPilot/ardupilot/issues/14054))
- [ ] TFMiniPlus Glitches ([issues](https://github.com/ArduPilot/ardupilot/issues/13411), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13765))
- [ ] dual CAN compass order changing ([discussion](https://discuss.ardupilot.org/t/can-compasses-selection/53153/9))
- [ ] can't flash kakutef7 aio from QGC ([issue](https://github.com/mavlink/qgroundcontrol/issues/8431))
- [ ] BLHeli passthrough still not reliable on CubeOrange ([discussion](https://discuss.ardupilot.org/t/orange-cube-4-0-and-blh-passthrough/51296/2))?
- [ ] vibration failsafe unable to bring down vehicle? ([discussion](https://discuss.ardupilot.org/t/quadcopter-fly-away/52948))
- [ ] blended mRo LocationOne GPSs (using AP_Periph, UAVCAN) produce internal error 400 ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-released/50545/79), [wiki issue](https://github.com/ArduPilot/ardupilot_wiki/issues/2557), [issue](https://github.com/ArduPilot/ardupilot/issues/14879))
- [ ] neopixel sync loss ([discussion](https://discuss.ardupilot.org/t/ws2812b-neopixel-integration/48580/74), [issue](https://github.com/ArduPilot/ardupilot/issues/13563))
- [ ] UAVCAN ESCs keep spinning even if vehicle is disarmed ([discussion](https://discuss.ardupilot.org/t/in-what-section-in-log-can-i-find-uavcan-escs-telemetry/51613), [issue](https://github.com/ArduPilot/ardupilot/issues/13394))
- [ ] kakutef7 not detecting external bmp280 baro? ([discussion](https://discuss.ardupilot.org/t/barometer-sinking-into-the-ground-when-doing-nothing/50935/10))
- [ ] [baro temp compensation](https://ardupilot.org/copter/docs/common-baro-temp-comp.html) not working? ([discussion](https://discuss.ardupilot.org/t/barometer-sinking-into-the-ground-when-doing-nothing/50935/11))
- [ ] neopixels not working on some boards at least? ([discussion](https://discuss.ardupilot.org/t/ws2812b-neopixel-integration/48580/18))
- [ ] kakutef7 aio doesn't detect hmc5883 ([discussion](https://discuss.ardupilot.org/t/compass-type-hmc5883-in-copter-4-0-0-tricopter-frame/50621))
- [x] durandal buzzer ([discussion](https://discuss.ardupilot.org/t/buzzer-on-durandal/50637))
- [ ] frsky passthrough not working on some H7 boards ([discussion](https://discuss.ardupilot.org/t/orange-cube-frsky-passthrough-and-mot-pwm-type-issues/48564/5))
- [ ] twitch when "IMU yaw alignment complete" is displayed while vehicle is moving (3.6.12) ([discussion](https://discuss.ardupilot.org/t/copter-3-6-12-rc1-released-for-beta-testing/50004/24))
- [ ] LIS3MDL driver not enabled on KakuteF7 ([discussion](https://discuss.ardupilot.org/t/kakute-f7-aio-enable-compass-greyed-out/41338), [issue](https://github.com/ArduPilot/ardupilot/issues/12512))
- [ ] Object Avoidance issues:
- [ ] Dijkstra's doesn't support spline waypoints (issue: https://github.com/ArduPilot/ardupilot/issues/12691)
- [ ] MP complex fence support is not complete
- [ ] dshot600 is not working on MatekF765 ([rover discussion](https://discuss.ardupilot.org/t/rover-4-0-matek-f765-blheli32-esc/48804))
- [ ] dshot125 is not working on Navio2 ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc2-available-for-beta-testing/48851/19))
- [ ] autotune gets stuck while tuning yaw if ATC_RAT_YAW_FLTE = 0 (reported by leonard)
- [ ] motor emergency stop RC channel range changed ([discussion](https://discuss.ardupilot.org/t/motor-kill-switch-behavior/48797/8))
- [ ] log download slows down when CAN enabled? ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc1-available-for-beta-testing/48545/52))
- [ ] navio2 LEDs not lighting up ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc2-available-for-beta-testing/48851/19))
- [ ] drift-away with WPNAV_ALT_MIN ([issue](https://github.com/ArduPilot/ardupilot/issues/12888), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13695))
Resolved in Copter-4.0.4:
- [x] Hott telemetry not working ([issue](https://discuss.ardupilot.org/t/copter-4-0-4-rc1-released-for-beta-testing/57203/45), [possible fix PR](https://github.com/ArduPilot/ardupilot/pull/14525))
- [x] Loiter-Turns mission command does not face towards center ([issue](https://github.com/ArduPilot/ardupilot/issues/14031), [possible fix](https://github.com/ArduPilot/ardupilot/pull/14038))
- [x] Dijkstra memory issue ([possible fix](https://github.com/ArduPilot/ardupilot/pull/13820))
- [x] extra RC input channel (actually Copter-3.6.12, [issue](https://github.com/ArduPilot/ardupilot/issues/13709)) -- RFD900x software issue - not AP.
- [x] parameters wiped occasionally (happens on 3.6.x as well) ([issue](https://github.com/ArduPilot/ardupilot/issues/13134), [fix](https://github.com/ArduPilot/ardupilot/pull/13780))
- [x] landing gear retract after takeoff mission command completes ([discussion](https://discuss.ardupilot.org/t/landing-gear-retract-on-auto-mission-start/51978), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13638))
- [x] Mavlink Gimbal limits not being applied? ([discussion](https://discuss.ardupilot.org/t/gimbal-limits-with-storm32-backend-mavlink-not-applied-correctly/51438/4), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13646))
- [x] Object Avoidance issues:
- [x] re-visit object database sizes: https://github.com/ArduPilot/ardupilot/issues/12661 (fixed in master)
- [x] BendyRuler cannot maintain altitude (Randy found this during tests) (fixed in master)
Resolved in Copter-4.0.3:
- [x] BLHeli passthrough doesn't work on CubeOrange ([discussion](https://discuss.ardupilot.org/t/orange-cube-4-0-and-blh-passthrough/51296/2), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13487)) and pixhawk mini?
- [x] watchdog on 1st SBUS RC input ([discussion](https://discuss.ardupilot.org/t/crash-following-rcinput-decoding-sbus/52290), [issue](https://github.com/ArduPilot/ardupilot/issues/13615), [fix](https://github.com/ArduPilot/ardupilot/pull/13619))
- [x] zigzag motors don't spin when landed ([issue](https://github.com/ArduPilot/ardupilot/issues/13471), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13501)) and lurching ([issue](https://github.com/ArduPilot/ardupilot/issues/13472))?
- [x] CUAVv5+ autopilot cannot connect using USB port? ([discussion](https://discuss.ardupilot.org/t/copter-4-0-2-rc3-available-for-beta-testing/51790/30), [discussion2](https://discuss.ardupilot.org/t/copter-4-0-2-rc4-available-for-beta-testing/52008/37), [driver solution](https://ardupilot.org/copter/docs/common-connect-mission-planner-autopilot.html#loading-composite-usb), [solution to fix usb ids](https://github.com/ArduPilot/ardupilot/pull/13179))
- [x] allow do-set-servo commands to affect at least some non-motor channels ([discussion](https://discuss.ardupilot.org/t/do-set-servo-in-spray-function-does-not-work-in-4-0-0/51950), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13481))
Resolved in Copter-4.0.2:
- [x] MAVFTP causes reboot ([issue](https://github.com/ArduPilot/ardupilot/issues/13085))
- [x] Spektrum DX8 not working on pixracer ([discussion](https://discuss.ardupilot.org/t/spektrum-dx8-radio-incompatible-not-recognized-with-arducopter-v-4-all-flavors/50702), [issue](https://github.com/ArduPilot/ardupilot/issues/13458))
- [x] RTL may return at incorrect alt ([issue](https://github.com/ArduPilot/ardupilot/issues/13441), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13444))
- [x] log file reliability on non-SD card boards like open-revo, omnibus ([discussion](https://discuss.ardupilot.org/t/tuning-the-harmonic-notch/48836/9))
- [x] SBUS lag ([discussion](https://discuss.ardupilot.org/t/urgent-s-bus-input-on-4-0-1-is-stuttering-often-100-300ms-up-to-500ms/51591), fixed along with ESC sync issues)
- [x] ESC sync issues ([discussion](https://discuss.ardupilot.org/t/esc-sync-problem-with-update-from-3-6-9-to-3-6-10/48261/5), [issue](https://github.com/ArduPilot/ardupilot/issues/13310), [issue2](https://github.com/ArduPilot/ardupilot/issues/13374))
- [x] AutoTune incorrectly restores yaw acceleration ([issue](https://github.com/ArduPilot/ardupilot/issues/13344), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13345))
- [x] px4flow doesn't work on CubeBlack ([discussion](https://discuss.ardupilot.org/t/px4flow-not-working-with-copter-4-0/51018), [fix](https://github.com/ArduPilot/ardupilot/pull/13391))
- [x] AP_RangeFinder PWM driver not using OFFSET parameter ([discussion](https://discuss.ardupilot.org/t/rngfnd1-offset-not-working-for-pwm-and-i2c-lidarlite/51125), [issue](https://github.com/ArduPilot/ardupilot/issues/13252), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13293))
Resolved in Copter-4.0.1:
- [x] need to update [tuning process guide](https://ardupilot.org/copter/docs/tuning-process-instructions.html) with new filter params ([discussion](https://discuss.ardupilot.org/t/what-should-i-use-for-atc-rat-pit-flt-values/49768/10))
- [x] spectrum 22ms broken? (https://discuss.ardupilot.org/t/mro-r15-pixracer-incompatible-with-arducopter-v-4/50702)
- [x] optical flow output not being sent to GCS ([discussion](https://discuss.ardupilot.org/t/cheerson-cx-of-low-cost-optical-flow-sensor-testing/35598/154), [possible fix](https://github.com/ArduPilot/ardupilot/pull/13182))
- [x] onboard SSD1306 not working with CubeOrange ([discussion](https://discuss.ardupilot.org/t/cube-orange-4-0-0-i2c-ssd1306-problem/50561), [issue](https://github.com/ArduPilot/ardupilot/issues/13127))
- [x] kakutef7mini watchdog resets ([discussion](https://discuss.ardupilot.org/t/prearm-internal-errors-0x800-watchdog-reset-reboot-with-kakute-f7-mini-logging-issue/50789)) (resolved with FrSky Telemetry Status Text fix)
Resolved in Copter-4.0.0-rc5:
- [x] RM3100 compass not enabled (it's on a DroTek F9P Sirius GPS unit) ([PR](https://github.com/ArduPilot/ardupilot/pull/10581), [discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc3-available-for-beta-testing/50250/19))
- [x] Arming with Here2 CAN GPS fails due to bad HDOP ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc2-available-for-beta-testing/48851/8), [fix](https://github.com/ArduPilot/ardupilot/pull/12916)) -- fixed in -rc3
- [x] autopilot is not booting up sometimes ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc3-rc4-available-for-beta-testing/50250/45), [fix](https://github.com/ArduPilot/ardupilot/commit/6b0252b44f4cf8bc71425345d918cb98e75937ff))
- [x] GPS not working on some boards ([possible fix](https://github.com/ArduPilot/ardupilot/commit/aad45986444f79444081b221045d9f2aea8eb90c))
- [x] missing serial ports on some boards ([possible fix](https://github.com/ArduPilot/ardupilot/commit/cac1cc0d9b6de101e7f4f275961331fe49d49b07))
Resolved in Copter-4.0.0-rc3:
- [x] sysid needs enable param ([issue](https://github.com/ArduPilot/ardupilot/issues/12927), [possible fix](https://github.com/ArduPilot/ardupilot/pull/12955))
- [x] user can force arming in Loiter with no position estimate ([issue](https://github.com/ArduPilot/ardupilot/issues/11435), [possible fix](https://github.com/ArduPilot/ardupilot/pull/12928))
- [x] rangefinder parameters not being copied from 3.6. to 4.0 ([issue](https://github.com/ArduPilot/ardupilot/issues/12921), [possible fix](https://github.com/ArduPilot/ardupilot/pull/12922))
- [x] neopixel not working ([discussion](https://discuss.ardupilot.org/t/ws2812b-neopixel-integration/48580))
- [x] altitude hold oscillation with CubeOrange ([discussion](https://discuss.ardupilot.org/t/alt-hold-issues-in-copter-4-0/48604), [fix](https://github.com/ArduPilot/ardupilot/pull/12898#event-2838474162))
- [x] rename RangeFinder_TYPE "25:Benewake TFmini Plusā to āBenewake TFmini Plus IICā or āBenewake Plus IICā ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-rc1-available-for-beta-testing/48545/52))
- [x] LandingGear: RETRACTED message where then are not gear setup ([issue](https://github.com/ArduPilot/ardupilot/issues/12815))
- [x] Auto may become stuck on Takeoff command if range finder is enabled and large altitude error ([issue](https://github.com/ArduPilot/ardupilot/issues/12818))
- [x] "Geofence breached" messages when no polygon fences available. Potential Fixed: https://github.com/ArduPilot/ardupilot/pull/12724
- [x] can't calibrate compasses ([discussion](https://discuss.ardupilot.org/t/compass-not-calibrated/48583/12)) -- older Here GPS with longer boot time, resolved by setting BRD_BOOT_DELAY = 400.
Resolved in Copter-4.0.0-rc2:
- [x] Sparky2 build is broken, overflows flash by1084 bytes. This can be seen in the autotest output. Fixed with https://github.com/ArduPilot/ardupilot/pull/12678
- [x] PSC_ACCZ_FILT should be converted to PSC_ACCZ_FLTE on upgrade. Fixed with https://github.com/ArduPilot/ardupilot/pull/12687
- [x] QGC upload of fences is rejected because of mav frame (qgc issue: https://github.com/mavlink/qgroundcontrol/issues/7960, AP fix:https://github.com/ArduPilot/ardupilot/pull/12665)
- [x] blank PreArm message on newly setup vehicles: https://github.com/ArduPilot/ardupilot/issues/11800. Fixed:https://github.com/ArduPilot/ardupilot/pull/12690
- [x] loss motor detection bug (reported by leonard) fixed:https://github.com/ArduPilot/ardupilot/pull/12697
- [x] loss of yaw control on fast descent ([from Sergey here](https://github.com/ArduPilot/ardupilot/issues/12695)). Fixed: https://github.com/ArduPilot/ardupilot/pull/12696, https://github.com/ArduPilot/ardupilot/pull/12700
- [x] fly away caused by high gains and mot-mix-max set too high (reported by leonard). Fixed:https://github.com/ArduPilot/ardupilot/pull/12701
- [x] BLHeli telemetry causes internal error 0x8000 (https://github.com/ArduPilot/ardupilot/issues/12542) potentially fixed by PR #12677
- [x] Shaky copter due to filtering changes
- [x] Garmin LidarLite PWM interface doesn't work: https://github.com/ArduPilot/ardupilot/issues/10111#issuecomment-546627151. User settings were non-standard, updated [wiki page](https://github.com/ArduPilot/ardupilot/issues/10111)
Could not be verified OR not a problem:
- [x] Emlid CAN compass not found with CubeOrange ([discussion](https://discuss.ardupilot.org/t/copter-4-0-1-rc3-available-for-beta-testing/51295/6)) unless BRD_BOOT_DELAY = 5000. Only affected one user, waiting for more reports.
- [x] blue screen of death on Windows machines when using usb2 ([discussion](https://discuss.ardupilot.org/t/copter-4-0-0-released/50545/18)). Affects only this user, could not be reproduced.
- [x] MiniPix current sensing not working ([discussion](https://discuss.ardupilot.org/t/copter-4-0-2-rc3-available-for-beta-testing/51790/4)). User worked it out.
- [x] constant GCS failsafes because crossfire telem sends heartbeat at 0.2hz ([discussion](https://discuss.ardupilot.org/t/failsafe-changes/48910)) -- telemetry system issue
- [x] rm3100 not found ([discussion](https://discuss.ardupilot.org/t/copter-4-0-1-released/51505/6))
- [x] DJIX quad motor order is CCW instead of CW ([discussion](https://discuss.ardupilot.org/t/copter-4-0-1-released/51505/20))
- [x] benewake jumps to 0.3m when actually 19m ~ 20m ([discussion](https://discuss.ardupilot.org/t/issue-with-lgr-deploy-and-or-rangefinder/51041)) -- benewake suggests a sensor setting change to resolve
- [x] complaints that RNGFND and BATT_MONITOR param conversions not working but cannot be reproduced ([discussion](https://discuss.ardupilot.org/t/copter-4-0-1-rc2-available-for-beta-testing-critical-fix-included/50940/16), [issue](https://github.com/ArduPilot/ardupilot/issues/13239))
- [x] omnibus f4pro can't write wp or parameters on serial1 ([discussion](https://discuss.ardupilot.org/t/omnibus-f4-pro-gps/50394/2))
- [x] rangefinder can't be used as EKF_ALT_SOURCE? ([issue](https://github.com/ArduPilot/ardupilot/issues/12991), [discussion](https://discuss.ardupilot.org/t/bug-in-ap-navekf2-posvelfusion-cpp/49919)) -- Randy tested and found EK2_ALT_SOURCE worked if EK2_RNG_USE_HGT was set to 70.
- [x] can't get IBUS RC to work ([discussion](https://discuss.ardupilot.org/t/am-i-doing-something-wrong-with-ibus/48789))
- [x] compass1,2 not used but still checked as part of pre-arm consistency? ([discussion](https://discuss.ardupilot.org/t/copter-3-6-12-rc1-released-for-beta-testing/50004/20))
