Issues & Pull Requests
Dev Call Dec 7, 2020
ArduPilot Dev Call 2020-12-07
Agenda:
Attendee count (max): 19
UTC1100 - https://github.com/ArduPilot/mavlink/pull/160
- Non-controversial PRs
- Looks fine
- Hard to validate the changes
- Need some automated help
- Something similar to EKF thing
- Generate headers
- Shift .h to one directory
- Then do a recursive diff and show the user
UTC1107 - https://github.com/ArduPilot/mavlink/pull/156/files
- Why doesnât the RP lidar map the quality onto a covariance?
- The field costs us bytes for no gain
UTC0114 - https://github.com/ArduPilot/ardupilot/pull/15990
- Takes away option from user to specify the distances
- Maybe take the minimum of the minimums?
- Larger of the minimums, shorter of the maximums
- Do whatever we do sending DISTANCE_SENSOR
- Can be merged after the min/max think
- Tag it documentation
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/15987
- Missing expected delays after flashing bootloaderâŚ
- Not a grace period coming out of delay?
- So any time we erase a sector we expect delaysâŚ
- Peter will merge it later today after having a bit of a look
- Internal error if you call delay for more than a certain amount of time and youâre on the main thread?
UTC1126 - https://github.com/ArduPilot/ardupilot/pull/15993
- AP_Periph with only uarts
- Doesnât link in DMA code if youâre not linking SPI
UTC1127 - https://github.com/ArduPilot/ardupilot/pull/15849
- SageTech driver
- Base conversion is weird
- Lose the generic nature of it
- Just do the octal conversions
- Avoid using brand names in serial protocols
UTC1146 - https://github.com/ArduPilot/ardupilot/pull/15108
- Use singleton to get airspeed sensor rather than asking AHRS for it
- Approved by tridge
- Tom will merge when heâs happy
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/15964
- From last week, rename GND to BARO
- BRD_OPTIONS bit to allow you to set parameters when you really want to be able to
- Right at the beginning put the subsystem name in Description for parameters
- MO will look at QNH
- 10:59 AM] Peter Hall: fairly sure MP QNH is actually QFE
UTC1149 - https://github.com/ArduPilot/ardupilot/pull/15774
- Includes the baro renames
- Rebase has broken thingsâŚ
- Parameters broken by bad rebase
- Multicopter compares tangential to rate of thrust to airspeed to get wind drift estimate
- Use wind drift estimate with speed to work out correction for barometer
- Using wind drift allows calculation of energy to return to home for mission optimisation
- Two components of drag modelled
- Normal drag (drag area * dynamic pressure)
- Scaled with speed squared
- Momentum drag (rotors produce lift)
- Scales with speed
- Two parameters
- One based on area of copter
- Frontal area
- Second is measured drag at a specific speed
- We print some estimates of what the parameters should be set to
- SITL model needs to match real Copter
- Tested on small quad
- Within 1m/s of wind drift
- Wind estimate goes over mavlink
- VFR_HUD.airspeed becomes airspeed estimate
- Only when this feature is enabled
- Momentum coefficient and ballistic coefficient
- Could be DRAG_
- Sponsor of this work wants more precise height control
- High speed on some multicopters causes low-pressure zones so the vehicle thinks it is too high
- Once tuned, these coefficients allow for no change in height for forward speed
- Position error coefficient
- Ratio of static to dynamic pressures
- Will be usable by Planes
- Internal baro that gets sucked down in pressure or an internal suffering from rammed-air can both be corrected
- Pusher-prop will give you a reasonable representation
- Tractors wonât work with thrust scaling yet
- Need a wind-based autotest for this
- Needs to get correct estimate and direction
- Can be merged mid-week without
- Thanks to Wattâs Communication for sponsoring this very cool work
UTC0010 - https://github.com/ArduPilot/ardupilot/pull/15826
- Fix guide mode spoolup and takeoff
- Randy has put comments on this and heâll discuss with Bill off-line
UTC0012 - https://github.com/ArduPilot/ardupilot/pull/15942
- Kris found this problem
- We may not push servo outputs with an undefined position
- Servos might go thwack and put a hole in a wing
- Init safety only after first loop
- Merged!
UTC0014 - https://github.com/ArduPilot/ardupilot/pull/15943
- ST note saying we shouldnât let unused pins on the chip float
- Pull them down
- So they are less susceptible to electrostatic damage
- We were defaulting to floating
- External pull-ups means we donât want to go all-pulldown
- Phillip K hsa checked all of the mRo boards and this will be set on those
- A manufacturer will need to check their boards for pullup/pulldown conflicts, create an exception list and then enable this option
- Active pull-down
- Push/pull and actively setting it zero
- Drive-down not a weak pull-down
- Need to poke manufacturers to check their boards
- Look at current draw before and afterwards
- Look at schematics for enable LEDs and the like
- Undefined pins bad
- Turning this on would turn LEDs off if they werenât defined correctly
- Actively used pins in the hwdef wonât be affected
UTC0021 - https://github.com/ArduPilot/ardupilot/pull/15951
- No accel limiting when reaching waypoints was why we werenât pivoting
- Was fixed, caused other bugs
- Reverted that and fixed it in another way
- Reverse in acro mode and then into auto mode would cause mission to be done in reverse
- Fixed
- Bug in throttle nudging code where
- No way of driving between wp speed and max speed
- Get_pilot_desired_speed reused to fix
- Anything non-zero may affect the speed
- Takes the maximum of pilot input and the wp speed
UTC0029 - https://github.com/ArduPilot/ardupilot/pull/15966
- Moving logging structures from Logger into NavEKF3
- merged
UTC0030 - https://github.com/ArduPilot/ardupilot/issues/15967
- Recent change impacts Plane a lot
- Compass-less Plane becomes difficult to arm
- Maybe we should honour COMPASS_USE and COMPASS_ENABLE in the sources stuff
- Compass object specifies whether the EKF3 should use it?
- Randy: Which sensor is used should be configuration in the EKF
- COMPASS_USE affects lots of subsystemsâŚ
- Users would have to change a lot of parametersâŚ.
- No parameters in barometer libraryâŚ.
- Airspeed does have airspeed_use
- Airspeed_use 0 is typical for first flights
- Randy doesnât like the COMPASS_USE parameters etc
- Source parameters into DCM?
- Treat USE as an enable parameter
- Trigger an error if you specify a source that doesnât exist
- You must set the source to None
- A whole bunch of fixed wing pilots find they canât fly because EK3_SRC_YAW is not-None
- DCM would also have to get compass-use parameters?
- Tridge wants and exception where we check the USE flag for compass
- Treat a EK3_SRC_YAW of compass as None if compass is disabled
- Randy: if you specify compass-for-yaw and you donât have one then youâve got a misconfiguration
- Compass and airspeed are difficult to test on the ground pre-flight
- VO is more modernâŚ
- TYPE parameter for enabling things
- EKF decides whether to use it or not
- Airspeed is used in lots and lots of places
- Plane uses it all over the place
- Kind of like rangefinder useâŚ.
- E.g. turning off rangefinder for terrain following and waypoint navigation and EKF use
- DCM and EKF3 are diverging in a compass-less Plane
- We keep re-fusing the same heading again and again
- People are looking at the actual issue of this PR
UTC0048 - https://github.com/ArduPilot/ardupilot/pull/11684
- Glitch protection
UTC0053 - https://github.com/ArduPilot/ardupilot/pull/13168
- Really ought to allow 0%
- Merged this documentation fix
UTC0055 - https://github.com/ArduPilot/ardupilot/pull/15451
- Makes sense
- Servo max/min donât do anything hereâŚ
- Scales against them
- Good change
- Peter will rebase it
UTC0057 - https://github.com/ArduPilot/ardupilot/pull/15359
- Decarotor support
- Merged!
UTC0059 - https://github.com/ArduPilot/ardupilot/pull/15973
- Merged!
- Logging fix
UTC0100 - https://github.com/ArduPilot/ardupilot/pull/15976
- Do we merge the paper-over
- Tridge thinks a bit of a bug-hunt would be better than merging this
UTC0102 - https://github.com/ArduPilot/ardupilot/pull/15982
- Merged
- Prettier enums
UTC0105 - https://github.com/ArduPilot/ardupilot/pull/15983
CubeBlack users might get annoyed because the second lane is often unhappy
A bunch of people might start to get warnings in flight where they didnât traditionally get them
Need an option bit for this?
- Support nightmareâŚ.
Need to turn this off if weâre sending mav1
Need to create MAV_OPTIONS parameter
- Rmackay9: GCS_OPTIONS or MAV_OPTIONS
We could create a new message
Partner had no visibility that their backup lanes were unhappy
- High-reliability vehicles need it
Off by default
UTC0115 - https://github.com/ArduPilot/ardupilot/pull/15995
- Random rudder movements would cause messages to GCS which is bad
- Tridge prefers Peterâs branch so Peter will PR and move that forward
UTC0122 - https://github.com/ArduPilot/ardupilot/pull/15999
- Lockup in scripting
- If semaphore is held by scripting and we try to take it in parameter when queue is full
- Disarmed lockup on vehicle if SD card goes out to lunch, potentially
- Needs to be discussed with MdB
UTC0126 - https://github.com/ArduPilot/ardupilot/pull/16001
- Consistent fence strings
- Merged!
UTC0127 - https://github.com/ArduPilot/ardupilot/pull/16002
- Bindings for location offset_bearing
- Merged!
UTC0127 - Plane update
- Tilt rotor push with Kris
- Big tasks for 4.1
UTC0127 - Copter update
- 4.1 progress
- S-curves
- Leonard has some work to do with terrain following
- End up a long way from target altitude
- S-curve output gets way ahead of vehicle
- S-curves need to be âslowed downâ
- Peter will be reviewing
- Switch to EKF3
- Only a few tests failingâŚ.
- S-curves
UTC0029 - Rover update
- No updateâŚ
UTC0030 - Community server with discord
- Should we turn it into a community server?
- If we start getting too much spam?
- Might allow us to go multi-admin
- Entry agreements into Community Server might be a thing?
- Validated email address only at this stageâŚ
- Leave it up to tridge and Tom, but you might have to validate your email addressâŚ
UTC0035 - Close
