Dev Call Aug 3, 2026
CI Workflows
Release Update
Issues & Pull Requests
Attendee count (max): 16
UTC2305 - CI ci · Workflow runs · ArduPilot/ardupilot · GitHub
  • 1 in 12 times we get a segfault
  • Couple of quick approval things perhaps
  • Couple of bad merges last DevCall which needed fixing
  • Infrastructure flake
UTC2314 - release update
UTC2330 - AP_Math: Add float cast to float version of fabsF by katzfey · Pull Request #28897 · ArduPilot/ardupilot · GitHub
  • fabsf vs fabsF
  • Use a pragma to quieten instead
  • We don’t use std::abs
UTC2342 - mavgen_c.py: make MAVLINK_*_XML_HASH deterministic by peterbarker · Pull Request #1240 · ArduPilot/pymavlink · GitHub
  • Make mavlink hash function deterministic
  • Merged!
UTC2347 - Create and optionally upload versioned amp.pdef.xml files during build by amilcarlucas · Pull Request #31355 · ArduPilot/ardupilot · GitHub
  • Freshing of parameters infrastructure fixes
  • Several requested changes from the AI
  • Peter’s comments haven’t been commented on
UTC2349 - AP_ExternalAHRS: Add Aeron Systems PLX3 INS Driver by VinayakPundhir · Pull Request #33041 · ArduPilot/ardupilot · GitHub
  • PLX3 ExternalAHRS
  • Likely to be merged soon
UTC0011 - AP_Param: avoid variable-length arrays in parameter conversion by peterbarker · Pull Request #33243 · ArduPilot/ardupilot · GitHub
  • Use a union instead of a vla when converting parameters
  • Merged!
UTC0016 - https://github.com/ArduPilot/ardupilot/pull/33328
  • E2-mini flight controller
  • Hipower enable stuff not same between the main firmware and bootloader
  • Needs a few tweaks
UTC0018 - AEDROXH7 FC - Update by Aedrox-UAx · Pull Request #33393 · ArduPilot/ardupilot · GitHub
  • AEDROXH7
  • Updating chibios and mavlink submodules - that’s no good!
UTC0019 - HAL_ChibiOS: Add Lectron Pi5 Autopilot board definitions by lectronuser · Pull Request #33423 · ArduPilot/ardupilot · GitHub
  • Add Lectron Li5 board definitions
UTC0025 - plane_follow.lua autotest with two SITL instances by timtuxworth · Pull Request #33432 · ArduPilot/ardupilot · GitHub
  • Plane follow autotest
  • Vast amounts of infrastructure changes
  • Multicast loopback kind of required vs what we’re currently doing
  • Peter will dig out his bi-lockstep-scheduling thing for Tim to look at
UTC0045 - Add board support for CUAV-X25-MEGA by cuav-chen2 · Pull Request #33475 · ArduPilot/ardupilot · GitHub
  • Add support for CUAV X25-mega
  • Needs the README.md for the ODID variant
UTC0048 - Move control limits into estimates structure by peterbarker · Pull Request #33606 · ArduPilot/ardupilot · GitHub
  • Control limits into structure
  • A few changes but can then be merged
UTC0010 - AP_NavEKF3: correct moving baseline GPS yaw for vehicle attitude by lthall · Pull Request #33706 · ArduPilot/ardupilot · GitHub
  • Correct moving baseline for GPS yaw
  • Needs some testing and compiler output change
UTC0011 - AP_Arming: Mission: check for zero takeoff alt by IamPete1 · Pull Request #33792 · ArduPilot/ardupilot · GitHub
  • Check for zero takeoff alt
  • Merged!
UTC0012 - CIRCLE (LOITER_TURNS) mission item using S-curves by lthall · Pull Request #33837 · ArduPilot/ardupilot · GitHub
  • Mission items using scurves
  • Request for people to look at this
UTC0015 - Plane: Quadplane: add a loiter stage in VTOL land approach with a loiter time of `Q_RTL_PAUSE_TIME` by IamPete1 · Pull Request #33842 · ArduPilot/ardupilot · GitHub
  • Add a loiter stage in VTOL land
  • Helps with tailsitters as they sometimes have trouble descending because they are unsettled
  • Some argument over the name of the method
UTC0018 - AP_Math: SCurve: remove redundant arc path_unit normalization by lthall · Pull Request #33860 · ArduPilot/ardupilot · GitHub
  • Remove redundant arch path optimisation
  • Merged!
UTC0020 - AP_Mission: fix get_next_nav_cmd by robertlong13 · Pull Request #33863 · ArduPilot/ardupilot · GitHub
  • Correct handling of jump commands
  • Thomas and Randy will look at it
  • Will probably merge
UTC0024 - QuadPlane: fix QLoiter backtransitions by robertlong13 · Pull Request #33874 · ArduPilot/ardupilot · GitHub
  • Fix QLoiter backtransitions
  • Stores state from forward transition and executes based on it on reverse transition
    • I.e. very stale!
  • Still needs to be an aggressive stop…
  • Lots of testing still required
  • We want a BRAKE view
UTC0033 - Allow for stabilization at zero throttle and zero rp demand when armed with airmode switch by peterbarker · Pull Request #33890 · ArduPilot/ardupilot · GitHub
  • Allow for stabilization at zero throttle in airmode
    • Was inconsistent
  • Merged!
UTC0038 - AP_Follow: discard target state when FOLL_SYSID changes by lthall · Pull Request #33891 · ArduPilot/ardupilot · GitHub
  • Follow target stuff
  • We’ll fix magically setting the sysid parameter
  • Will work with Randy
UTC0052 - VTX power up state · Issue #33918 · ArduPilot/ardupilot · GitHub
  • Default vtx power to on or to off?
  • Andy and Henry are disagreeing.
  • Please put your comments on the PR!
UTC0055 - Fix ending comments where the `#endif // COMMENT` didn't match the opening if by peterbarker · Pull Request #33920 · ArduPilot/ardupilot · GitHub
  • Fix closing comments
  • merged
UTC0056 - AP_HAL_ChibiOS: don't fake CAN send success in bootloader builds by lthall · Pull Request #33922 · ArduPilot/ardupilot · GitHub
  • Don’t send fake CAN send success in bootloader builds
  • Merged!
  • Probably only two or three peripherals to worry about
    • Bus-off?!
      • No, won’t hear people seeing your message
    • No successful sends and bus-offs mean you’re not connected?
UTC0104 - Tools: ros2: tear down rclpy cleanly in the AP_DDS tests by peterbarker · Pull Request #33894 · ArduPilot/ardupilot · GitHub
  • Fix segfault in DDS
  • Merged!
UTC0109 - partner meeting tomorrow night
UTC0111 - PLX AHRS marked for MergeOnCIPass
UTC0011 - close
