Attendee count (max): 17
UTC2300 - https://github.com/ArduPilot/pymavlink/pull/406
- Peter to do patches for MAVExplorer to show this in use
UTC2308 - https://github.com/ArduPilot/ardupilot/pull/14265
- Sending statustexts more efficient
- Back after being tested
- Merged!
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/15607
- Navigator LED
- Needed testing
- Merged!
UTC2311 - https://github.com/ArduPilot/ardupilot/pull/16091
- Moves rudder arming stuff up into RC channel
- Unrelated bug found in quadplane arming
- Ignore rudder while taking off?
- Copter has landing detection which ignores rudder on ground
- Takeoff and auto-arming?
- Race condition getting stick back to neutral?
- Auto-trim looks odd?
- Move save_trim back onto Copter
- Fix continuous calls to arming checks
UTC2336 - https://github.com/ArduPilot/ardupilot/pull/16506
- WoW weight one wheels switch (WoW can be waiting-on-weather)
- WoW causes vehicles to consider themselves landed more easily
- General agreement that being able to use weight-on-wheels as an absolute is a good idea
- Needs testing on a real vehicle
- merged
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/16515/files
- Ned to use tnow rather than AP_HAL::millis()
- Needs a rebase and handling of tnow
UTC0007 - https://github.com/ArduPilot/ardupilot/pull/16535
- Tested on hardware now
- frontend/backend split for external ahrs
- What would a generic NMEA parser look like?
- Could use vectornav on a Copter now
- Dozens of manufacturers making very expensive serially-connected IMUs
- Fibre-optic gyros?
- Needs review
- Would be good to be able to degrade performance in SITL to trigger EKF failsafes
- Tridge is changing m/s errors into innovations to fit our repoirting
UTC0014 - https://github.com/ArduPilot/ardupilot/pull/16676
- Flush out stuff before rebooting in SITL
- Merged
UTC0022 - https://github.com/ArduPilot/ardupilot/pull/16787
- For DevCallEU?
- PH has looked at this
- LEDs working nicely after this
UTC0023 - https://github.com/ArduPilot/ardupilot/pull/16976
- Memsic device….
- Can be merged once its passed CI
UTC0030 - https://github.com/ArduPilot/ardupilot/pull/16995
- Built on top of the memsic compass support
- Random other bits and pieces that are navigator-specific
UTC0030 - https://github.com/ArduPilot/ardupilot/pull/17031
- Climb-before-turn not quite right
- Don’t want to asymptote
- We’re probably subtracting wrong altitude frames
UTC0038 - https://github.com/ArduPilot/ardupilot/pull/17034
- Stop watchdogging on log erase
UTC0041 - https://github.com/ArduPilot/ardupilot/pull/17050
- Redefine output distance logic on teraranger
- Tell difference between dead sensor and out-of-rnage
- Essentially reverts MdB’s change
- 13376
- Merged
UTC0044 - https://github.com/ArduPilot/ardupilot/pull/17052
- Uavcan slot preservation
- merged
UTC0045 - https://github.com/ArduPilot/ardupilot/pull/17072
UTC0045 - https://github.com/ArduPilot/ardupilot/pull/17081
- Gets back some DMA memory
- Lots of LEDs again
- Master you can only do 30 or 40 and you run out of memory
- I2c4 and spi6 - restrictions of matrix of what RAM regions you can use
- I2c4 might be broken ATM
- PH to check these mappingsto make sure boards aren’t broken
UTC0055 - cygwin packages / 64-bit stuff
- 32/64-bit windows
- We need to use 32-bit packages so we get 32-bit binaries
- Stephen is helping out
UTC0056 - https://github.com/ArduPilot/ardupilot/pull/17098
- Terrain and quadplane fixes
- Put pre-generated terrain file in which will be cool
UTC003 - Conference and stuff
- This weekend!
- Friday/Saturday/Sunday Canberra time
- Schedule:
- Might still be spots if you wanted to give a talk
- Slide templates coming in
- Rishabh’s been puttinga lot of time in on the object avoidance stuff
- Test links in various channels - please help audio/visual setup
- Zoom call details published just before call starts
UTC0007 - Copter/Rover
- Beta testing before end of the week?
- So people can try out some of the cool stuff
- No blockers for beta as far as we’re aware
- Some annoying but not dangerous problems
- PR to fix OA with SCurves
- Rishabh is still look at this
- Vehicle moves around too much
- Still finding bugs
- Might still have a problem in quaternion controller
- EKF3 has a few issues that will need to be addressed before release
- E.g. yaw estimate wandering off
- Randy saw on Rover
- Maybe same as Andy’s behaviour
- Calling stuff “rc” is maybe not a good thing
- Plane isn’t ready
- Bandwidth from Paul?
- Need to frame the announcement - and not using “rc”!
- Tough to get testing together just within dev team
- Need wider use
- Want to get it out soon-ish
UTC0027 - https://github.com/ArduPilot/ardupilot/pull/17106
- Bi-direcitonal d-shot for revo-mini
- Word problem in semaphore
- DevCallEU
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/17109
UTC0033 - https://github.com/ArduPilot/ardupilot/pull/17107
- Merged
- Bdshot on kakutef7
UTC0034 - Plane update
- New autotune is looking really good
- Completely new PID system is looking good
UTC0035 - close
