opened 03:30AM - 31 Jan 24 UTC
Copter
Rover
DevCallTopic
ReleaseAdmin
This is a list of issues discovered during Copter and Rover 4.5 testing. The [is…sues list for Copter/Rover-4.4 is here](https://github.com/ArduPilot/ardupilot/issues/23192).
[Backport PRs](https://github.com/orgs/ArduPilot/projects/8/views/1).
Reports requiring investigation:
- [ ] KakuteH7 fails to initialise ([discussion](https://discuss.ardupilot.org/t/kakute-h7-gps-and-radio-problem/115931))
- [ ] SmartRTL flow of control error ([pre-existing issue](https://github.com/ArduPilot/ardupilot/issues/17416))
- [ ] Developer issues integrating CAN RangeFinder ([discussion1](https://discuss.ardupilot.org/t/issues-with-interegrating-can-sensor-using-lua/115585/5), [discussion2](https://discuss.ardupilot.org/t/help-related-to-dronecan/115874), [issue](https://github.com/ArduPilot/ardupilot/issues/26704))
- [ ] DShot 600 jerky movement without being armed ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-released/115614/21)) -- configuration error (MOT_PWM_TYPE = 0 but SERVO_BLH_MASK non-zero)
- [ ] ROS2 / DDS install issues ([discussion1](https://discuss.ardupilot.org/t/compiling-arducopter-4-5-0-with-enable-dds-failed/115632), [discussion2](https://discuss.ardupilot.org/t/colcon-build-packages-up-to-ardupilot-dds-tests-failed/115720))
- [ ] T265 not working ([discussion](https://discuss.ardupilot.org/t/vision-positioning-using-t265-does-not-work/115679))
- [ ] Near Fly-away with 4.4.4 (EKF failsafe was disabled, [discussion](https://discuss.ardupilot.org/t/internal-errors-0x400-l-856-cnstring-nan-uncontrollable-behavior-in-rtl-and-loiter/115598))
- [ ] Pixhawk 6C SBUS out not working with Tarot gimbal ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-released/115614/12))
- [ ] GPS_TYPE parameter descriptions in MP using 4.4 ([issue](https://github.com/ArduPilot/ardupilot/issues/26681#issuecomment-2034416514))
- [ ] Lua mount:set-angle-target binding doesn't work on Matek H743 mini V3 ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-released/115614/3))
- [ ] RPLidarS1 erratic distances on Rover ([discussion](https://discuss.ardupilot.org/t/rplidar-s1-erratic-distances/115561), [possible fix](https://github.com/rmackay9/rmackay9-ardupilot/commits/rover-rplidar-update-rate/))
- [ ] CAM messages with Img field "0" appearing in logs without pictures being taken (reported by Randy)
- [ ] Throw mode reliability ([discussion](https://discuss.ardupilot.org/t/diagnose-unpredictable-throw-mode/113314))
Confirmed issues:
- [ ] EKF Wind estimates not available when using GPS-for-yaw ([issue](https://github.com/ArduPilot/ardupilot/issues/26650))
- [ ] APM_Config can't be used to include/exclude features ([issue](https://github.com/ArduPilot/ardupilot/issues/26654))
- [ ] Neopixels broken ([discussion](https://discuss.ardupilot.org/t/multiple-neopixels-dont-flash-in-sync/113620), [issue](https://github.com/ArduPilot/ardupilot/issues/26295), [PR-to-blame](https://github.com/ArduPilot/ardupilot/pull/23974))
Enhancements or Issues that may not be resolved before the stable release:
- [ ] Custom Build server support for CUAV Pixhack v3x with 3 IMUs ([discussion](https://discuss.ardupilot.org/t/ardupilot-custom-firmware-builder-fmuv3-missing-necessary-for-cuav-pixhack-v3x/115823), [product page](https://www.cuav.net/en/pixhack-v3-autopilot/))
- [ ] AP_OSD: Add CRSF link stats display fields ([PR](https://github.com/ArduPilot/ardupilot/pull/25844))
- [ ] Network params not visible for Pixhawk5x ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-beta2-available-for-beta-testing/113156/13), [issue](https://github.com/ArduPilot/ardupilot/issues/26397))
- [ ] ViewPro does not track GPS location well ([discussion](https://discuss.ardupilot.org/t/viewpro-gimbal-point-camera-here-function/98279/33), known limitation of ViewPro API)
Wiki issues/enhancement requests:
- [x] Auto mode LOITER_TURNS does not support CCW? ([discussion](https://discuss.ardupilot.org/t/ccw-loiter-turns/114282))
- [ ] Add vertical position controller tuning instructions ([discussion](https://discuss.ardupilot.org/t/z-oscillation-in-position-hold/113149/4))
- [x] Add warning for AutoTune ESC desync ([issue](https://github.com/ArduPilot/ardupilot_wiki/issues/5760))
Mission planner issues/enhancement requests:
- [ ] fixup camera gimbal page ([discussion](https://discuss.ardupilot.org/t/question-about-camera-gimbal/101063/7))
- [ ] Loiter turns radius incorrect ([issue](https://github.com/ArduPilot/MissionPlanner/issues/3305))
QGC issues/enhancement requests:
- [x] QGC sending invalid roll, pitch, yaw angles ([discussion](https://discuss.ardupilot.org/t/mount-invalid-angle-targets-problem/113885), [QGC issue](https://github.com/mavlink/qgroundcontrol/issues/11215))
Resolved issues:
- [x] Siyi mount stalls occasionally and bouncing near pitch and yaw limits ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-beta4-available-for-beta-testing/115149/11)) -- Siyi firmware / hardware mismatch
- [x] Pixhawk6C compass issue ([4.4 issue](https://github.com/ArduPilot/ardupilot/issues/25946), [4.5 discussion](https://discuss.ardupilot.org/t/copter-4-5-0-beta2-available-for-beta-testing/113156/3)) -- no feedback
- [x] do-condition-yaw bug (also in 4.4, [PR](https://github.com/ArduPilot/ardupilot/pull/24719)) -- resolved for beta5 (assuming there is a beta5)
- [x] Copters turns North in Guided_NoGPS ([issue](https://github.com/ArduPilot/ardupilot/issues/26357), [discussion](https://discuss.ardupilot.org/t/set-attitude-target-with-guided-no-gps-lack-of-documentation/111845/24), [PR](https://github.com/ArduPilot/ardupilot/pull/26407)) -- fixed for beta5 (assuming there is a -beta5)
- [x] ViewPro not holding level during hard maneuvers ([PR](https://github.com/ArduPilot/ardupilot/pull/26556)) -- resolved in beta4 (although no confirmation from user) -- fixed for beta5 (assuming there is a -beta5)
- [x] altitude jump when GPS/Non-GPS transitions switching altitude source of ExtNav to Baro (reported by Randy) -- should jump when moving from camera->baro, cannot reproduce otherwise.
- [x] MP's MAVFtp can't download SYS files ([MP issue](https://github.com/ArduPilot/MissionPlanner/issues/3309)) -- SITL only issue
- [x] Logging removed on some boards? ([issue](https://github.com/ArduPilot/CustomBuild/issues/70), [PR](https://github.com/ArduPilot/ardupilot/pull/26421)) -- needs backport?
- [x] Sending unknown message ([issue](https://github.com/ArduPilot/ardupilot/issues/26358), [PR](https://github.com/ArduPilot/ardupilot/pull/26361)) -- resolved for -beta3
- [x] increasing k_format_version does not reset parameters (dev question, [issue](https://github.com/ArduPilot/ardupilot/issues/26336)) -- cannot reproduce, responses stopped
- [x] MAV_CMD_DO_SEND_SCRIPT_MESSAGE not working? ([discussion](https://discuss.ardupilot.org/t/is-mav-cmd-do-send-script-message-unsupported-on-copter-4-5/113787)) -- only supported as Mission command
- [x] TKOFF_RPM_MIN working? ([4.3.x discussion](https://discuss.ardupilot.org/t/takeoff-blocked-waiting-for-esc-rpm/113256)) -- fixed in 4.4
- [x] Record video while armed broken ([PR](https://github.com/ArduPilot/ardupilot/pull/26217)) -- resolved for -beta3
- [x] Parachute conversion issue ([issue](https://github.com/ArduPilot/ardupilot/issues/26132), [PR](https://github.com/ArduPilot/ardupilot/pull/26151)) -- resolved for beta2
- [x] Siyi running old camera fw message ([discussion](https://discuss.ardupilot.org/t/siyi-a8-camera-fw-version-reporting-issue/112870), [original discussion](https://discuss.ardupilot.org/t/siyi-a8-mini-4k-ai-mini-zoom-gimbal-camera-ai-identify-tracking-4k-1-1-7-inch-8mp-sony-sensor-6x-zoom/92133/673), [PR](https://github.com/ArduPilot/ardupilot/pull/26168)) -- resolved for beta2
- [x] Matek H743 watchdog ([discussion](https://discuss.ardupilot.org/t/locally-compiled-arducopter-4-5-0-beta1-fails-on-matekh743-due-to-watchdog/113029)) -- development environment issue
- [x] Stuck thread ([discussion](https://discuss.ardupilot.org/t/stuck-thread-and-failed-data-logging-error/112711/2)) -- exists in 4.4.4 as well, two devs say it's fine so concluded it is a hardware failure on the user's autopilot.
- [x] AutoTune crash -- ESC de-sync ([discussion](https://discuss.ardupilot.org/t/copter-4-5-0-beta1-available-for-beta-testing/112504/11))
- [x] Here4 does not support GPS-for-yaw (aka Moving baseline) ([discussion](https://discuss.ardupilot.org/t/gps-yaw-moving-baseline-with-dual-dronecan-here4/112357))
