Issues & Pull Requests
GSOC
Plane
- Flyaway
- Update
Copter
Rover
GSOC
Plane
Copter
Rover
Attendee count (max): 18
UTC2303 - https://github.com/ArduPilot/ardupilot/pull/11113
UTC2304 - fly-away
Mini-pix plane
Flew a long way away
Mini-pix froze completely
Constant throttle, constant control surfaces
Major investigation
Remediations into ArduPilot
Barometer was obviously misbehaving
Failed on ground
GCS operator didn’t note the height was incorrect
No arming check for gps/baro consistency
Can’t have been under autonomous control because of faulty barometer (height-holding would have made for a wild ride)
Theory is error on barometer spread to IMU and it failed
Main loop stopped
Timers continue with normal PWM, so constant throttle and constant control surfaces
Perfectly trimmed aircraft
Proposal is that we enable to hw watchdog functionality on stm32
Reboot in flight after 1 second of no patting
Fast boot
Will be disarmed
Motor will be off
New BRD_OPTIONS
Bit to enable the watchdog
Once started it can’t be stopped without a reboot
Must be patted once/second
Default on for Plane
Massive scheduler outage means reboot
Functions in code to say expect a delay of some time
Compass calibration
Opening logs
1kHz timer takes over dog-patting duty
Send statustext on reboot and a sys_status bit
Will be going into Plane stable
New pre-arm checks for baro
Some devteam members have concerns over the continued support of the board
Multiple failures
If we stop support then users won’t get any fixes for ArduPilot
Does MO think it worth adding a warning to MP?
Add a note to the Wiki?
Random problems on discuss and facebook
[9:22 AM] (Channel) buzz_mobile: I think we should do mitigations first, push them, and make sure the latest version of firmware available to this board has the watchdog fix, and then give warnings to user in wiki, etc.
PK: Banning is a waste of time, they will just update the bootloader to mimic any other supported board.
Can’t currently attempt to reproduce due to restrictions in place
Safety switch state?
BRD_SAFTY_ENABLE often on
No outputs at all
State after reboot?
Last-safety-state parameter?
Backup register?
Copter will simply plummet on reboot
Helicopters?
Autorotations?
Disarmed but with servos active
Need torque on the servos?
MdB: Re servos: that depends entirely on brand
[9:35 AM] (Channel) MdB: IE I use servos that either hold last, or go to a failsafe position
1 second a reasonable timeout?
Well beyond normal scheduling errors?
Too long == no control for longer
Too short == false positives
JW: What about user configurable with a hard coded floor?
Needs a new bootloader to be flashed so the bootloader doesn’t wait for 5 seconds on boot
Deviations of 25-30ms we sometimes see
buzz_mobile: I don’t think a vehicle that is flying should ever disarm itself,
Separate radio-inputs-in-failsafe PR
UTC2345 - https://github.com/ArduPilot/ardupilot/pull/11111
Merged
Fixes actual bugs
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/11102
Implies nav_pitch_cd is incorrect
Tridge wants to root-cause the problem rather than patching over it
UTC2349 - https://github.com/ArduPilot/ardupilot/pull/11095
Change is probably harmless
Should be flight-tested on ms5611
Why aren’t we using floats here?!
Pressure-sensor for depth?
Need to get Jacob to test it
Either change to floats
Tridge would prefer to change to float
Makes the code more similar to others
UTC2353 - https://github.com/ArduPilot/ardupilot/pull/11094
Which CI
Need to broaden travis build to build all vehicles
UTC2359 - https://github.com/ArduPilot/ardupilot/pull/11093
UTC0000 - https://github.com/ArduPilot/ardupilot/pull/11092/files
Kill the rotate thing
Can merge the remaining small patch
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/11085
Tridge will look at the code more carefully
Tridge is convinced
UTC0011 - https://github.com/ArduPilot/ardupilot/pull/11078
Rangefinder arming checks
Existential check
Make sure we can actually create a backend and disallow arming if we can’t
Had to do param conversion because we ran out of arming bits
Not converting parameters on Sub - need tridge’s help
Pre-arm check for being within some distance of ground before arming
Forward-facing rangefinders could screw up prearm heck
Returning true if no singleton?
EKF requires rangefinder to be passed in
Shouldn’t being called if no rangefinder
Tridge: Always shift with 1U rather than 1
Will remove the silly range-of-movement rangefinder check
UTC0017 - https://github.com/ArduPilot/ardupilot/pull/11073
UTC0026 - https://github.com/ArduPilot/ardupilot/pull/11067
Needs a test
Current_loc always has to be altitude-above-home
UTC0029 - GSoC update
42 submissions
Student application window closed
Quite a few have been reviewed
Got 20 in the last 24 hours of the submission window
During the devcall next week is the deadline, pretty much
Doubtless more good applications than we have
UTC0030 - Plane update
New release coming RSN
Nice RealFlight8 model
Ideal for tailsitter simulations
Convergence tilt-tricopter quadplane model
CAN servos from HiTec working for first time with a patch
A few errors in the firmware which have been worked around
Will probably need a flag in uavcan as to whether to send separate frames
UTC0032 - Copter update
New beta coming soon
New board support
Cxof
Septentrino patch too
Pixhawk6 change
Same as pixhawk4pro
Pull-up fixes thanks to cuav
Copter 3.7
Better object avoidance
New OF sensor from
UTC0038 - Rover
No plans on release issues
Vision projects channel
People are having luck with the realsense vision stuff
Good position estimation up to 30m
Object avoidance in althold mode
Want to move navigation to library
UTC0045 - neopixel
UTC0046 - https://github.com/ArduPilot/ardupilot/pull/11059
Restoring throttle-min in Plane
Enumeration doesn’t seem to have correct effect
Tridge wants to think about this some more
UTC0048 - https://github.com/ArduPilot/ardupilot/pull/11053
UTC0050 - https://github.com/ArduPilot/ardupilot/pull/11042/files
UTC0054 - https://github.com/ArduPilot/ardupilot/pull/11027
UTC0055 - HEX/ProfiCNC flow sensor
MdB reviewed this
Initialising uavcan driver within run?
Seems to be done a bit within uavcan
Randy doesn’t like it
[10:57 AM] (Channel) MdB: https://github.com/ArduPilot/ardupilot/pull/11017/files#diff-5b9552bc19d73f965211c65ba417f722R130 <- this
Tridge: Where sensor types have a type they should remain unhealthy until a sensor turns up
So autodetection at startup but if something has been specified it can turn up later
UTC0102 - https://github.com/ArduPilot/ardupilot/pull/10996
Throttle mid-point
Should there be two sets of acro-rate parameters?
UTC0104 - Close
