Vicsea
(VPathak)
October 11, 2019, 8:40pm
1
I am having issue with my copter flipping as soon as I throttle up. I have confirmed the motor and the propeller configuration and can only think it may be the ESC Calibration.
I calibrated using “Normal” ESC Type and now starting to wonder if it is right.
I have LHI Simonk 30A ESC . How do I know what ESC Type that is?
Thanks in advance.
dkemxr
(Dave)
October 11, 2019, 8:51pm
2
Those are plain vanilla PWM. Set MOT_PWM_TYPE to 0 (normal).
It’s almost always motor order or prop direction causing this. Double check with Motor Test in Mission Planner
Vicsea
(VPathak)
October 11, 2019, 9:26pm
3
You response is much appreciated.
I have done motor test where clicking “Test Motor A” drives “Motor 1”, B drives 2, C drives 3 and D drives 4.
Also, I can guess the motor spin and propeller are correct since the air blows down when I click on any of the “Test Motor”.
My configuration is as follows:
Thanks again
dkemxr
(Dave)
October 11, 2019, 9:46pm
4
That is incorrect. Read the note about order on the Mission Planner motor test page.
A-1
B-4
C-2
D-3
Clockwise from front right.
