I just changed from NTM 2830-800kv motors, to T-motor MN3110-780kv motors, and now i am able to provoke motor desync. This is the scenario:
The propellers are off, i calibrate the ESC’s and when i am able to test the motors, i can provoke a desync, randomly on all motors if i quickly go from eg. 5% to 70%. Its usually when i am NOT throttling to 100%.
The same goes if i use motor test in mission planner.
If i plug in the ESC to my RX i cant provoke desync. I don’t belive all 6 escs are broken at the same time.
The new motors are 14 poles, and the old was 12 poles… Is it a setting in BL heli?
Thanks…
