Desired altitude changes without throttle input in loiter mode
I have an issue flying my small non-GPS quad in loiter mode. The altitude is changing sporadically without any throttle input from my side. The change is within 1 meter usually but sometimes goes bigger than that. Looking at the log I see that the desired altitude is changing but I don’t get the reason why:
Note: I am flying indoors.
The quad is fitted with the OPTICAL FLOW 3901-L0X from Matek, and the rangefinder on it is configured as the secondary POS_Z source for the EK3, however it’s not giving me continuous data above 1m.
Does anyone know what could be the reason for this? I would expect the desired altitude to be constant and the relative altitude to follow it closely.
Air pressure noise caused by air movement. Protect your baro better. And learn about Venturi and Bertuli effects.
You read that use of the range finder on the module is not recommended right?
Matek optflow
Yes, I am not relying on it as a primary source and I intend to have it replaced with something better soon. Thank you.
Thank you for the info, my baro was indeed exposed. I didn’t believe that covering it would help too much but it really did. The altitude is much more constant now. But I see something strange on the log. The altitude reported by the baro seems to have an offset from the real altitude. I flew the drone at about 1.5 meters and here is what I’m seeing:
What do you think is causing this?
Now it’s time for you to use:Quick start guide | MethodicConfigurator
And ask more questions once you completed it.
