I have a question about new parameters since 3.0.1 that I upgraded to 3.1:
-MOT_TCRV_MAXPCT : i see “93” in the value column, while it is indicated “20 80” in the options value (min, max I suppose?). How was this 93 value fixed as this parameter did not exist in 3.0.1? Should I reduce it then to 80 ?
Hughes,
thanks for posting the question in the forum. So it’s a display issue. It should read 50~100 so we will have a look for the cause.
No need to change that parameter, it should be fine at 93. It’s for linear-izing the output to the ESCs and has been around for a while.
