i have a big problem with the installation from source.
I opend the terminal and i follow the command in readme but i stuck on this command: qmake qgroundcontrol.pro.
That is what happend:
michael@michael12:~/apm_planner$ qmake qgroundcontrol.pro
Project MESSAGE: Qt version 5.2.1
Project MESSAGE: Linux build x86
Project MESSAGE: Release flavor
Project MESSAGE: BASEDIR /home/michael/apm_planner DESTDIR /home/michael/apm_planner/release TARGET apmplanner2
Project MESSAGE: Skipping support for QUpgrade
Project MESSAGE: Using mavlink + ardupilotmega
Project MESSAGE: Skipping support for OpenSceneGraph
Project MESSAGE: Skipping support for Google Earth
Project MESSAGE: Skipping support for Protocol Buffers
Project MESSAGE: Skipping support for libfreenect
Project MESSAGE: Adding ALGLIB /home/michael/apm_planner/libs/alglib
Project MESSAGE: Skipping support for XBee
Project MESSAGE: Skipping support for Opal-RT
Project MESSAGE: QTDIR /opt/Qt5.2.1/5.2.1/gcc_64
WARNING: permFolders.path is not defined: install target not created
WARNING: permFiles.path is not defined: install target not created
I have only copied the last part of it with the error.
In file included from src/uas/UAS.h:36:0,
from src/input/JoystickInput.cc:15:
src/comm/MAVLinkProtocol.h:57:10: warning: unused parameter ‘msg’ [-Wunused-parameter]
void sendMessage(mavlink_message_t msg) { }
src/input/JoystickInput.cc: In member function ‘bool JoystickInput::sdlJoystickUpdate(unsigned int)’:
src/input/JoystickInput.cc:280:54: error: ‘SDL_TICKS_PASSED’ was not declared in this scope
if (SDL_TICKS_PASSED(ticks, valuesTicks + timeout))
make: *** [build-release/obj/JoystickInput.o] Fehler 1
Her are the Terminal output:
libsdl1.2-dev is already the newest version.
libsdl2-dev is already the newest version.
libsndfile1-dev is already the newest version.
Thanks for the find carpy, I’ll get a debian VM up today and see if that’s the issue. Can you try adding that package qudrocopter92, and see if it helps?
