Death spiral roll in acro
Hello. After unsuccessful loop in acro mode plane goes into death spiral roll. I tried to stop the rotation with the sticks. At some point, it stopped. But as soon as you let go of the sticks, it returned again.
https://1drv.ms/u/s!AuFPVI_eDaZbh4E15NCZ5WeBzfvxSA?e=2dFvGy
Freewing F-35
Plane 4.2.1
Here full video. Crash in the end
Not understand why this happens.
I think the plane stalled. You can see a similar stall at ~1:38 in the video and in the logs. In each case the airspeed dropped to about 40km/h. With the high bank angles that might not be enough for that airframe. Acro mode is a rate control mode, so stall recovery can be difficult. As noted in the wiki it is best to switch to manual mode before attempting to recover.
Edit: At 1:38 the plane was in FBWA. That coupled with your stick inputs is likely why the stall was successfully recovered.
Thank you. I came to about the same conclusions. But I wanted to hear a second opinion.
Just curious, what did you use to generate the telemetry overlay on the video?
this is dashware overlay
