DC Air Valve to control with Pixhawk
Has anyone come across a cost effective DC Air Valve that I can control with PixHawk FC. I can handle 3.3V AUX out to convert it to 12VDC or whatever voltage the valve may require to turn it on.
My application is as follows:
  1. I have one air pump that uses a very low pressure of PSI 0.02MP to 0.25MP. So it’s a very low pressure pump.
  2. I would preferably want one valve that would has one input and 3 or 4 outputs.
So, at any given time. I will be just turning on one value to redirect the air.
The possible solutions I know are;
  1. Use like 3 x single valve shown below and use tubes to connect them.
Cumbersome, need external tubes etc. not a clean solution.
Any other ideas?
thanks
Maybe something like an air retract valve
Malc
