Is the data flash log kept on the simulator? Like you’d have on the sdcard on a “real” flight controller?
If so, where?
If so, where?
Documents\Mission Planner\sitl\logs
Thanks!! Found it at Documents\Mission Planner\sitl\plane\logs
pbarker@bluebottle:~/rc/ardupilot(master)$ ls logs
00000003.BIN 00000004.BIN LASTLOG.TXT
Peter
Thanks all, I discovered a trick - if you’ve done a mapping mission but there was no SD card inserted in the FC, just re-run the whole mission in the sim and collect the log there Not perfect but at least the data is not lost and you can geotag your images!
