Does anybody have any dataflash log files for a Rover? I want to see how they are structured because I am trying to understand how the Replay logs functionality works. Thanks.
I have tried to use some .bin files I found in the forums but I always get “bad log header” when I use Tools/Replay.elf on them.
The logging code is identical between vehicles so Rover, Copter, Plane all log in the same way using the same structure. Obviously some entries might be missing - you won’t see air speed sensor logs in a Rover but the structure is the same.
Thanks, Grant.
