- #include "Copter.h"
- #if HAL_LOGGING_ENABLED
- // Code to Write and Read packets from AP_Logger log memory
- // Code to interact with the user to dump or erase logs
- struct PACKED log_Control_Tuning {
- LOG_PACKET_HEADER;
- uint64_t time_us;
- float throttle_in;
- float angle_boost;
- float throttle_out;
- float throttle_hover;
- float desired_alt;
- float inav_alt;
- int32_t baro_alt;
- float desired_rangefinder_alt;
- float rangefinder_alt;
- float terr_alt;
- int16_t target_climb_rate;
- int16_t climb_rate;
- // Write a control tuning packet
- void Copter::Log_Write_Control_Tuning()
- // get terrain altitude
- float terr_alt = 0.0f;
- #if AP_TERRAIN_AVAILABLE
- if (!terrain.height_above_terrain(terr_alt, true)) {
- terr_alt = logger.quiet_nan();
- #endif
- float des_alt_m = 0.0f;
- int16_t target_climb_rate_cms = 0;
- if (!flightmode->has_manual_throttle()) {
- des_alt_m = pos_control->get_pos_target_z_cm() * 0.01f;
- target_climb_rate_cms = pos_control->get_vel_target_z_cms();
- // get surface tracking alts
- if (!surface_tracking.get_target_dist_for_logging(desired_rangefinder_alt)) {
- desired_rangefinder_alt = AP::logger().quiet_nan();
- struct log_Control_Tuning pkt = {
- LOG_PACKET_HEADER_INIT(LOG_CONTROL_TUNING_MSG),
- time_us : AP_HAL::micros64(),
- throttle_in : attitude_control->get_throttle_in(),
- angle_boost : attitude_control->angle_boost(),
- throttle_out : motors->get_throttle(),
- throttle_hover : motors->get_throttle_hover(),
- desired_alt : des_alt_m,
- inav_alt : inertial_nav.get_position_z_up_cm() * 0.01f,
- baro_alt : baro_alt,
- desired_rangefinder_alt : desired_rangefinder_alt,
- rangefinder_alt : surface_tracking.get_dist_for_logging(),
- terr_alt : terr_alt,
- target_climb_rate : target_climb_rate_cms,
- climb_rate : int16_t(inertial_nav.get_velocity_z_up_cms()) // float -> int16_t
- logger.WriteBlock(&pkt, sizeof(pkt));
- // Write an attitude packet
- void Copter::Log_Write_Attitude()
- Vector3f targets = attitude_control->get_att_target_euler_cd();
- targets.z = wrap_360_cd(targets.z);
- ahrs.Write_Attitude(targets);
- ahrs_view->Write_Rate(*motors, *attitude_control, *pos_control);
- // Write PIDS packets
- void Copter::Log_Write_PIDS()
- if (should_log(MASK_LOG_PID)) {
- logger.Write_PID(LOG_PIDR_MSG, attitude_control->get_rate_roll_pid().get_pid_info());
- logger.Write_PID(LOG_PIDP_MSG, attitude_control->get_rate_pitch_pid().get_pid_info());
- logger.Write_PID(LOG_PIDY_MSG, attitude_control->get_rate_yaw_pid().get_pid_info());
- logger.Write_PID(LOG_PIDA_MSG, pos_control->get_accel_z_pid().get_pid_info() );
- if (should_log(MASK_LOG_NTUN) && (flightmode->requires_GPS() || landing_with_GPS())) {
- logger.Write_PID(LOG_PIDN_MSG, pos_control->get_vel_xy_pid().get_pid_info_x());
- logger.Write_PID(LOG_PIDE_MSG, pos_control->get_vel_xy_pid().get_pid_info_y());
- // Write an EKF and POS packet
- void Copter::Log_Write_EKF_POS()
- AP::ahrs().Log_Write();
- struct PACKED log_Data_Int16t {
- uint64_t time_us;
- uint8_t id;
- int16_t data_value;
- // Write an int16_t data packet
- UNUSED_FUNCTION
- void Copter::Log_Write_Data(LogDataID id, int16_t value)
- if (should_log(MASK_LOG_ANY)) {
- struct log_Data_Int16t pkt = {
- LOG_PACKET_HEADER_INIT(LOG_DATA_INT16_MSG),
- id : (uint8_t)id,
- data_value : value
- logger.WriteCriticalBlock(&pkt, sizeof(pkt));
- struct PACKED log_Data_UInt16t {
- uint64_t time_us;
- uint8_t id;
- uint16_t data_value;
- // Write an uint16_t data packet
- UNUSED_FUNCTION
- void Copter::Log_Write_Data(LogDataID id, uint16_t value)
- struct log_Data_UInt16t pkt = {
- LOG_PACKET_HEADER_INIT(LOG_DATA_UINT16_MSG),
- id : (uint8_t)id,
- struct PACKED log_Data_Int32t {
- uint64_t time_us;
- uint8_t id;
- int32_t data_value;
- // Write an int32_t data packet
- void Copter::Log_Write_Data(LogDataID id, int32_t value)
- struct log_Data_Int32t pkt = {
- LOG_PACKET_HEADER_INIT(LOG_DATA_INT32_MSG),
- id : (uint8_t)id,
- struct PACKED log_Data_UInt32t {
- uint64_t time_us;
- uint8_t id;
- uint32_t data_value;
- // Write a uint32_t data packet
- void Copter::Log_Write_Data(LogDataID id, uint32_t value)
- struct log_Data_UInt32t pkt = {
- LOG_PACKET_HEADER_INIT(LOG_DATA_UINT32_MSG),
- id : (uint8_t)id,
- struct PACKED log_Data_Float {
- uint64_t time_us;
- uint8_t id;
- float data_value;
- // Write a float data packet
- UNUSED_FUNCTION
- void Copter::Log_Write_Data(LogDataID id, float value)
- struct log_Data_Float pkt = {
- LOG_PACKET_HEADER_INIT(LOG_DATA_FLOAT_MSG),
- id : (uint8_t)id,
- struct PACKED log_ParameterTuning {
- uint64_t time_us;
- uint8_t parameter; // parameter we are tuning, e.g. 39 is CH6_CIRCLE_RATE
- float tuning_value; // normalized value used inside tuning() function
- float tuning_min; // tuning minimum value
- float tuning_max; // tuning maximum value
- void Copter::Log_Write_Parameter_Tuning(uint8_t param, float tuning_val, float tune_min, float tune_max)
- struct log_ParameterTuning pkt_tune = {
- LOG_PACKET_HEADER_INIT(LOG_PARAMTUNE_MSG),
- parameter : param,
- tuning_value : tuning_val,
- tuning_min : tune_min,
- tuning_max : tune_max
- logger.WriteBlock(&pkt_tune, sizeof(pkt_tune));
- void Copter::Log_Video_Stabilisation()
- if (!should_log(MASK_LOG_VIDEO_STABILISATION)) {
- return;
- ahrs.write_video_stabilisation();
- struct PACKED log_SysIdD {
- uint64_t time_us;
- float waveform_time;
- float waveform_sample;
- float waveform_freq;
- float angle_x;
- float angle_y;
- float angle_z;
- float accel_x;
- float accel_y;
- float accel_z;
- // Write an rate packet
- void Copter::Log_Write_SysID_Data(float waveform_time, float waveform_sample, float waveform_freq, float angle_x, float angle_y, float angle_z, float accel_x, float accel_y, float accel_z)
- #if MODE_SYSTEMID_ENABLED == ENABLED
- struct log_SysIdD pkt_sidd = {
- LOG_PACKET_HEADER_INIT(LOG_SYSIDD_MSG),
- waveform_time : waveform_time,
- waveform_sample : waveform_sample,
- waveform_freq : waveform_freq,
- angle_x : angle_x,
- angle_y : angle_y,
- angle_z : angle_z,
- accel_x : accel_x,
- accel_y : accel_y,
- accel_z : accel_z
- logger.WriteBlock(&pkt_sidd, sizeof(pkt_sidd));
- #endif
- struct PACKED log_SysIdS {
- uint64_t time_us;
- uint8_t systemID_axis;
- float waveform_magnitude;
- float frequency_start;
- float frequency_stop;
- float time_fade_in;
- float time_const_freq;
- float time_record;
- float time_fade_out;
- void Copter::Log_Write_SysID_Setup(uint8_t systemID_axis, float waveform_magnitude, float frequency_start, float frequency_stop, float time_fade_in, float time_const_freq, float time_record, float time_fade_out)
- struct log_SysIdS pkt_sids = {
- LOG_PACKET_HEADER_INIT(LOG_SYSIDS_MSG),
- systemID_axis : systemID_axis,
- waveform_magnitude : waveform_magnitude,
- frequency_start : frequency_start,
- frequency_stop : frequency_stop,
- time_fade_in : time_fade_in,
- time_const_freq : time_const_freq,
- time_record : time_record,
- time_fade_out : time_fade_out
- logger.WriteBlock(&pkt_sids, sizeof(pkt_sids));
- #endif
- #if FRAME_CONFIG == HELI_FRAME
- struct PACKED log_Heli {
- uint64_t time_us;
- float desired_rotor_speed;
- float main_rotor_speed;
- float governor_output;
- float control_output;
- // Write an helicopter packet
- void Copter::Log_Write_Heli()
- struct log_Heli pkt_heli = {
- LOG_PACKET_HEADER_INIT(LOG_HELI_MSG),
- desired_rotor_speed : motors->get_desired_rotor_speed(),
- main_rotor_speed : motors->get_main_rotor_speed(),
- governor_output : motors->get_governor_output(),
- control_output : motors->get_control_output(),
- logger.WriteBlock(&pkt_heli, sizeof(pkt_heli));
- #endif
- // guided position target logging
- struct PACKED log_Guided_Position_Target {
- uint64_t time_us;
- uint8_t type;
- float pos_target_x;
- float pos_target_y;
- float pos_target_z;
- uint8_t terrain;
- float vel_target_x;
- float vel_target_y;
- float vel_target_z;
- float accel_target_x;
- float accel_target_y;
- float accel_target_z;
- // guided attitude target logging
- struct PACKED log_Guided_Attitude_Target {
- uint64_t time_us;
- uint8_t type;
- float roll;
- float pitch;
- float yaw;
- float roll_rate;
- float pitch_rate;
- float yaw_rate;
- float thrust;
- float climb_rate;
- // Write a Guided mode position target
- // pos_target is lat, lon, alt OR offset from ekf origin in cm
- // terrain should be 0 if pos_target.z is alt-above-ekf-origin, 1 if alt-above-terrain
- // vel_target is cm/s
- void Copter::Log_Write_Guided_Position_Target(ModeGuided::SubMode target_type, const Vector3f& pos_target, bool terrain_alt, const Vector3f& vel_target, const Vector3f& accel_target)
- const log_Guided_Position_Target pkt {
- LOG_PACKET_HEADER_INIT(LOG_GUIDED_POSITION_TARGET_MSG),
- type : (uint8_t)target_type,
- pos_target_x : pos_target.x,
- pos_target_y : pos_target.y,
- pos_target_z : pos_target.z,
- terrain : terrain_alt,
- vel_target_x : vel_target.x,
- vel_target_y : vel_target.y,
- vel_target_z : vel_target.z,
- accel_target_x : accel_target.x,
- accel_target_y : accel_target.y,
- accel_target_z : accel_target.z
- // Write a Guided mode attitude target
- // roll, pitch and yaw are in radians
- // ang_vel: angular velocity, [roll rate, pitch_rate, yaw_rate] in radians/sec
- // thrust is between 0 to 1
- // climb_rate is in (m/s)
- void Copter::Log_Write_Guided_Attitude_Target(ModeGuided::SubMode target_type, float roll, float pitch, float yaw, const Vector3f &ang_vel, float thrust, float climb_rate)
- const log_Guided_Attitude_Target pkt {
- LOG_PACKET_HEADER_INIT(LOG_GUIDED_ATTITUDE_TARGET_MSG),
- roll : degrees(roll), // rad to deg
- pitch : degrees(pitch), // rad to deg
- yaw : degrees(yaw), // rad to deg
- roll_rate : degrees(ang_vel.x), // rad/s to deg/s
- pitch_rate : degrees(ang_vel.y), // rad/s to deg/s
- yaw_rate : degrees(ang_vel.z), // rad/s to deg/s
- thrust : thrust,
- climb_rate : climb_rate
- // type and unit information can be found in
- // libraries/AP_Logger/Logstructure.h; search for "log_Units" for
- // units and "Format characters" for field type information
- const struct LogStructure Copter::log_structure[] = {
- LOG_COMMON_STRUCTURES,
- // @LoggerMessage: PTUN
- // @Description: Parameter Tuning information
- // @URL: https://ardupilot.org/copter/docs/tuning.html#in-flight-tuning
- // @Field: TimeUS: Time since system startup
- // @Field: Param: Parameter being tuned
- // @Field: TunVal: Normalized value used inside tuning() function
- // @Field: TunMin: Tuning minimum limit
- // @Field: TunMax: Tuning maximum limit
- { LOG_PARAMTUNE_MSG, sizeof(log_ParameterTuning),
- "PTUN", "QBfff", "TimeUS,Param,TunVal,TunMin,TunMax", "s----", "F----" },
- // @LoggerMessage: CTUN
- // @Description: Control Tuning information
- // @Field: ThI: throttle input
- // @Field: ABst: angle boost
- // @Field: ThO: throttle output
- // @Field: ThH: calculated hover throttle
- // @Field: DAlt: desired altitude
- // @Field: Alt: achieved altitude
- // @Field: BAlt: barometric altitude
- // @Field: DSAlt: desired rangefinder altitude
- // @Field: SAlt: achieved rangefinder altitude
- // @Field: TAlt: terrain altitude
- // @Field: DCRt: desired climb rate
- // @Field: CRt: climb rate
- // @LoggerMessage: D16
- // @Description: Generic 16-bit-signed-integer storage
- // @Field: Id: Data type identifier
- // @Field: Value: Value
- // @LoggerMessage: DU16
- // @Description: Generic 16-bit-unsigned-integer storage
- // @LoggerMessage: D32
- // @Description: Generic 32-bit-signed-integer storage
- // @LoggerMessage: DFLT
- // @Description: Generic float storage
- // @LoggerMessage: DU32
- // @Description: Generic 32-bit-unsigned-integer storage
- { LOG_CONTROL_TUNING_MSG, sizeof(log_Control_Tuning),
- "CTUN", "Qffffffefffhh", "TimeUS,ThI,ABst,ThO,ThH,DAlt,Alt,BAlt,DSAlt,SAlt,TAlt,DCRt,CRt", "s----mmmmmmnn", "F----00B000BB" , true },
- { LOG_DATA_INT16_MSG, sizeof(log_Data_Int16t),
- "D16", "QBh", "TimeUS,Id,Value", "s--", "F--" },
- { LOG_DATA_UINT16_MSG, sizeof(log_Data_UInt16t),
- "DU16", "QBH", "TimeUS,Id,Value", "s--", "F--" },
- { LOG_DATA_INT32_MSG, sizeof(log_Data_Int32t),
- "D32", "QBi", "TimeUS,Id,Value", "s--", "F--" },
- { LOG_DATA_UINT32_MSG, sizeof(log_Data_UInt32t),
- "DU32", "QBI", "TimeUS,Id,Value", "s--", "F--" },
- { LOG_DATA_FLOAT_MSG, sizeof(log_Data_Float),
- "DFLT", "QBf", "TimeUS,Id,Value", "s--", "F--" },
- // @LoggerMessage: HELI
- // @Description: Helicopter related messages
- // @Field: DRRPM: Desired rotor speed
- // @Field: ERRPM: Estimated rotor speed
- // @Field: Gov: Governor Output
- // @Field: Throt: Throttle output
- { LOG_HELI_MSG, sizeof(log_Heli),
- "HELI", "Qffff", "TimeUS,DRRPM,ERRPM,Gov,Throt", "s----", "F----" , true },
- #endif
- // @LoggerMessage: SIDD
- // @Description: System ID data
- // @Field: Time: Time reference for waveform
- // @Field: Targ: Current waveform sample
- // @Field: F: Instantaneous waveform frequency
- // @Field: Gx: Delta angle, X-Axis
- // @Field: Gy: Delta angle, Y-Axis
- // @Field: Gz: Delta angle, Z-Axis
- // @Field: Ax: Delta velocity, X-Axis
- // @Field: Ay: Delta velocity, Y-Axis
- // @Field: Az: Delta velocity, Z-Axis
- { LOG_SYSIDD_MSG, sizeof(log_SysIdD),
- "SIDD", "Qfffffffff", "TimeUS,Time,Targ,F,Gx,Gy,Gz,Ax,Ay,Az", "ss-zkkkooo", "F---------" , true },
- // @LoggerMessage: SIDS
- // @Description: System ID settings
- // @Field: Ax: The axis which is being excited
- // @Field: Mag: Magnitude of the chirp waveform
- // @Field: FSt: Frequency at the start of chirp
- // @Field: FSp: Frequency at the end of chirp
- // @Field: TFin: Time to reach maximum amplitude of chirp
- // @Field: TC: Time at constant frequency before chirp starts
- // @Field: TR: Time taken to complete chirp waveform
- // @Field: TFout: Time to reach zero amplitude after chirp finishes
- { LOG_SYSIDS_MSG, sizeof(log_SysIdS),
- "SIDS", "QBfffffff", "TimeUS,Ax,Mag,FSt,FSp,TFin,TC,TR,TFout", "s--ssssss", "F--------" , true },
- // @LoggerMessage: GUIP
- // @Description: Guided mode position target information
- // @Field: Type: Type of guided mode
- // @Field: pX: Target position, X-Axis
- // @Field: pY: Target position, Y-Axis
- // @Field: pZ: Target position, Z-Axis
- // @Field: Terrain: Target position, Z-Axis is alt above terrain
- // @Field: vX: Target velocity, X-Axis
- // @Field: vY: Target velocity, Y-Axis
- // @Field: vZ: Target velocity, Z-Axis
- // @Field: aX: Target acceleration, X-Axis
- // @Field: aY: Target acceleration, Y-Axis
- // @Field: aZ: Target acceleration, Z-Axis
- { LOG_GUIDED_POSITION_TARGET_MSG, sizeof(log_Guided_Position_Target),
- "GUIP", "QBfffbffffff", "TimeUS,Type,pX,pY,pZ,Terrain,vX,vY,vZ,aX,aY,aZ", "s-mmm-nnnooo", "F-BBB-BBBBBB" , true },
- // @LoggerMessage: GUIA
- // @Description: Guided mode attitude target information
- // @Field: Roll: Target attitude, Roll
- // @Field: Pitch: Target attitude, Pitch
- // @Field: Yaw: Target attitude, Yaw
- // @Field: RollRt: Roll rate
- // @Field: PitchRt: Pitch rate
- // @Field: YawRt: Yaw rate
- // @Field: Thrust: Thrust
- // @Field: ClimbRt: Climb rate
- { LOG_GUIDED_ATTITUDE_TARGET_MSG, sizeof(log_Guided_Attitude_Target),
- "GUIA", "QBffffffff", "TimeUS,Type,Roll,Pitch,Yaw,RollRt,PitchRt,YawRt,Thrust,ClimbRt", "s-dddkkk-n", "F-000000-0" , true },
- uint8_t Copter::get_num_log_structures() const
- return ARRAY_SIZE(log_structure);
- void Copter::Log_Write_Vehicle_Startup_Messages()
- // only 200(?) bytes are guaranteed by AP_Logger
- char frame_and_type_string[30];
- copter.motors->get_frame_and_type_string(frame_and_type_string, ARRAY_SIZE(frame_and_type_string));
- logger.Write_MessageF("%s", frame_and_type_string);
- logger.Write_Mode((uint8_t)flightmode->mode_number(), control_mode_reason);
- ahrs.Log_Write_Home_And_Origin();
- gps.Write_AP_Logger_Log_Startup_messages();
- #endif // HAL_LOGGING_ENABLED
This file has been truncated. show original
