Custom Messages working on SITL, but not on Hardware
I want to send and receive a custom message via mavlink telemetry link. I defined the message definition in the ardupilotmega.xml file, added a handler in GCS_Mavlink.cpp, and ran a few tests in SITL. I was able to send the message via pymavlink using the following code:
master = mavutil.mavlink_connection('udp:127.0.0.1:14550')
master.mav.send(
            mavutil.mavlink.MAVLink_thumbnail_message(
                Packet = f"{packet_num}".encode(),
                Data = msg.encode(),
Also, I was able to read this message on a remote system using the following code:
master = mavutil.mavlink_connection('udp:127.0.0.1:14552')
msg = master.recv_msg()
        if msg:
            msg = msg.to_dict()
            # print(msg)
            if msg["mavpackettype"] == "
                print("**********************************")
                print("Packet Found!")
                print(msg)
Then I compiled the code for CubeOrange using:
./waf configure --board CubeOrange
and
./waf copter
Then uploaded the firmware to the board and tested the same. The message is not being received by the remote system. Even it stopped working in SITL ;(
I checked the GCM_Mavlink library in the build>CubeOrange>libraries directory, it contains the message deffinintions (mavlink_message_thumbnail.h) file as well.
Any help would be appreciated.
Thanks
For additional info:
Changes in ardupilotmega.xml file:
Changes in …/ArduCopter/GCS_Mavlink.h:
Changes in …/ArduCopter/GCS_Mavlink.cpp:
are you open udp port on your board?
if you have error please take screenshot
The issue was resolved.
The problem was that occasionally pymavlink used MAVLINK1 instead of MAVLINK2. And as this message was defined for MAVLINK2, it did not worked. I added the check to use MAVLINK2 only, and now it works.
Thanks
