The current reading on my pixhawk isn’t working anymore in Mission Planner
Looking at the logs of yesterday the current is being logged
What has changed
I changed to a T-Motor P50A 6S BLHeli 32 4in1 ESC. I didn’t look at the current reading when I installed the ESC so I don’t know if this happened when I installed the ESC and I don’t know if an ESC will cause this issue
I replaced the Runcam 2S split with a Caddx Ant camera
What has not changed for the past 2 months
I have not upgraded to the new firmware yet
I am still using the standard power module
https://ardupilot.org/copter/docs/common-3dr-power-module.html
I can’t remember if I upgraded Mission Planner in 2 months. The current version is 1.3.75 build 1.3.7893.12317 Arducopter V4.0.7 (0bb18a15)
This was my parameters 13 September. I know it worked at this point because it was showing ±600mA when I was running the Runcam Split 2s. When I load these parameters the current reading doesn’t work in Mission Planner.
https://drive.google.com/file/d/1oG9mNR-dHvVZ8y8Qw9KjOzHG5_3sZpAp/view?usp=sharing
When I changed the camera I remember posting it was only drawing about 150mA 14th of October it was still working.
This is the current parameter list
https://drive.google.com/file/d/16SwQ7gikjrbff1R4AFYT52z2f0ohmE6y/view?usp=sharing
So I don’t know if I changed something in Mission Planner that I wasn’t supposed to change. This issue is on my laptop and on my PC. I doubt I would have made the same change on both computers because I normally use the laptop.
