Servers by jDrones
Current Arduplane has a compiler error: acos not found?
(Me) #1
I’m getting a compiler error trying to build the current master Ardupilot. How do I fix this ?
git clone https://github.com/ArduPilot/ardupilot.git
cd ardupilot
git submodule update --init --recursive
./waf configure --board Pixhawk1
./waf plane
Compilation terminated due to -Wfatal-errors.
In file included from …/…/libraries/AP_Common/missing/cmath:3:0,
from …/…/libraries/AP_HAL/CAN.h:23,
from …/…/libraries/AP_HAL/HAL.h:17,
from …/…/libraries/AP_HAL/AP_HAL_Main.h:19,
from …/…/libraries/AP_HAL/AP_HAL.h:8,
from …/…/libraries/AC_WPNav/AC_WPNav.cpp:1:
/usr/arm-none-eabi/include/c++/7.4.0/cmath:83:11: error: ‘::acos’ has not been declared
using ::acos;
compilation terminated due to -Wfatal-errors.
Waf: Leaving directory `/home/me/workspace/ardupilot/build/Pixhawk1’
Build failed
-> task in ‘objs/AC_WPNav’ failed (exit status 1):
{task 140559548615208: cxx AC_Circle.cpp -> AC_Circle.cpp.0.o}
(run with -v to display more information)
-> task in ‘objs/AC_AutoTune’ failed (exit status 1):
{task 140559548814112: cxx AC_AutoTune.cpp -> AC_AutoTune.cpp.0.o}
{task 140559548615328: cxx AC_Loiter.cpp -> AC_Loiter.cpp.0.o}
-> task in ‘objs/APM_Control’ failed (exit status 1):
{task 140559548613888: cxx AP_YawController.cpp -> AP_YawController.cpp.0.o}
{task 140559548613648: cxx AP_RollController.cpp -> AP_RollController.cpp.0.o}
{task 140559548615448: cxx AC_WPNav.cpp -> AC_WPNav.cpp.0.o}
dnf list arduino*
Installed Packages
arduino.noarch 1:1.8.5-6.fc29 @updates
arduino-builder.x86_64 1.3.25-1.fc28 @fedora
arduino-core.noarch 1:1.8.5-6.fc29 @updates
arduino-ctags.x86_64 5.8-8.arduino11.fc29 @fedora
arduino-listSerialPortsC.x86_64 1.4.0-3.fc29 @fedora
(Me) #2
Also this:
git clone --single-branch --branch ArduPlane-release https://github.com/ArduPilot/ardupilot.git
./waf plane
[16/479] Compiling libraries/AC_PID/AC_HELI_PID.cpp
In file included from /usr/arm-none-eabi/include/c++/7.4.0/cmath:45:0,
from …/…/libraries/AP_Common/missing/cmath:3,
from …/…/libraries/AC_Fence/AC_Fence.cpp:1:
/usr/arm-none-eabi/include/math.h:314:35: error: macro “fmax” passed 2 arguments, but takes just 1
extern double fmax (double, double);
I’m running Fedora 29.
(tridge) #3
Please use one of the compilers recommended here:
http://firmware.ardupilot.org/Tools/STM32-tools/
(Me) #4
Thanks, I’ll give one of them a try.
Can you recommend a way to install them such that they coexist with another ARM toolset of a newer version ?
(Me) #5
I’m digging into this deeper. I’d really like to run the arm-gcc-non-eabi package that ships on Fedora 29. I’m not exactly sure why this error is happening. I don’t see anything in the diff that alerts me to an issue with acos.
$ dnf list arm*
Installed Packages
arm-image-installer.noarch 2.10-1.fc29
arm-none-eabi-binutils-cs.x86_64 1:2.32-1.fc29
arm-none-eabi-gcc-cs.x86_64 1:7.4.0-1.fc29
arm-none-eabi-gcc-cs-c++.x86_64 1:7.4.0-1.fc29
$ diff /usr/arm-none-eabi/include/c++/7.4.0/cmath /home/me/Downloads/gcc-arm-none-eabi-6-2017-q2-update/arm-none-eabi/include/c++/6.3.1/cmath
3c3
< // Copyright (C) 1997-2017 Free Software Foundation, Inc.
> // Copyright (C) 1997-2016 Free Software Foundation, Inc.
47d46
< #include <bits/std_abs.h>
52a52
> #undef abs
82a83,105
> #ifndef __CORRECT_ISO_CPP_MATH_H_PROTO
>   inline _GLIBCXX_CONSTEXPR double
>   abs(double __x)
>   { return __builtin_fabs(__x); }
> #endif
>   inline _GLIBCXX_CONSTEXPR float
>   abs(float __x)
>   { return __builtin_fabsf(__x); }
>   inline _GLIBCXX_CONSTEXPR long double
>   abs(long double __x)
>   { return __builtin_fabsl(__x); }
> #endif
>   template<typename _Tp>
>     typename __gnu_cxx::__enable_if<__is_integer<_Tp>::__value,
>                                     double>::__type
>     abs(_Tp __x)
1015d1037
< #ifndef _GLIBCXX_NO_C99_ROUNDING_FUNCS
1022d1043
< #endif
1148d1168
1156d1175
< #endif
1866,1913c1885
< #if __cplusplus > 201402L
< namespace std _GLIBCXX_VISIBILITY(default)
< _GLIBCXX_BEGIN_NAMESPACE_VERSION
<   // [c.math.hypot3], three-dimensional hypotenuse
< #define __cpp_lib_hypot 201603
<   template<typename _Tp>
<     inline _Tp
<     __hypot3(_Tp __x, _Tp __y, _Tp __z)
<       __x = std::abs(__x);
<       __y = std::abs(__y);
<       __z = std::abs(__z);
<       if (_Tp __a = __x < __y ? __y < __z ? __z : __y : __x < __z ? __z : __x)
<       return __a * std::sqrt((__x / __a) * (__x / __a)
<                              + (__y / __a) * (__y / __a)
<                              + (__z / __a) * (__z / __a));
<       else
<       return {};
<   inline float
<   hypot(float __x, float __y, float __z)
<   { return std::__hypot3<float>(__x, __y, __z); }
<   inline double
<   hypot(double __x, double __y, double __z)
<   { return std::__hypot3<double>(__x, __y, __z); }
<   inline long double
<   hypot(long double __x, long double __y, long double __z)
<   { return std::__hypot3<long double>(__x, __y, __z); }
<   template<typename _Tp, typename _Up, typename _Vp>
<     typename __gnu_cxx::__promote_3<_Tp, _Up, _Vp>::__type
<     hypot(_Tp __x, _Up __y, _Vp __z)
<       using __type = typename __gnu_cxx::__promote_3<_Tp, _Up, _Vp>::__type;
<       return std::__hypot3<__type>(__x, __y, __z);
< _GLIBCXX_END_NAMESPACE_VERSION
< } // namespace
< #endif // C++17
< #if _GLIBCXX_USE_STD_SPEC_FUNCS
> #if __STDCPP_WANT_MATH_SPEC_FUNCS__ == 1
[me@Brix ~]$ diff /usr/arm-none-eabi/include/c++/7.4.0/cmath  /home/me/Downloads/gcc-arm-none-eabi-6-2017-q2-update/arm-none-eabi/include/c++/6.3.1/cmath
3c3
47d46
52a52
> #undef abs
82a83,105
>   abs(double __x)
> #endif
>   abs(float __x)
> #endif
>                                     double>::__type
>     abs(_Tp __x)
1015d1037
1022d1043
< #endif
1148d1168
1156d1175
< #endif
1866,1913c1885
<     inline _Tp
<       else
<       return {};
<   inline float
<   inline double
< } // namespace
< #endif // C++17
(peterbarker) #7
There’s a preview feature. Usually the markup is ``` for block-quotes.
Onto your problem.
We specify the compiler we support in several different places. We’re
kind of picky so we don’t have to worry about multiple compiler versions
too much - but it does mean the compiler we’re currently using is ancient.
We will move forwardat some stage - but it does require a lot of flight
testing to ensure nothing has gone awry.
You might consider installing the compiler we generally use. The prereq
install scripts specify the version:
(Me) #8
Thank you.
I understand the project’s predicament - gcc changes quite a bit lately. I also understand how to install the toolchains in the link provided. The main issue is that I work on other ARM projects using STM32F processors and I don’t see an easy way to have both toolchains installed simultaneously without renaming things and adjusting makefiles.
Any ideas ?
I don’t mean to sound ungrateful to the Ardupilot team when I make this comment.
