Cubepilot Orange + No PWM Output at Servo Rails
I recently purchased a Cubepilot Orange + and after configuring I realize that there is no PWM signal coming from the servo rail. I have the latest stable version of 4.5.7 loaded currently and have disable as many of the pre-arm checks and safety interlock that I can think of. Any suggestions on what to look at next??
Turn the arming checks back to 1. They will save you.
Set BRD_SAFETY_MASK to the channels you want. Note that Throttle outputs will still be blocked unless the plane is armed. Also note that the servo rail is not powered so you need to provide power to the servos from an external BEC.
Copy will give this a shot now, thanks!!
Excellent that worked!!!
