Hey guys I have a problem. Just bought a Cube Pilot Orange brand new and when I plug it in it does nothing except turn on an orange light. I’ve bought Orange cubes before and as soon as I plug it in out of the box I get the chime and can connect via MP. Does anyone know how to diagnose/fix it. Thanks
They now come with no firmware on board at all. You will need to installed the latest drivers for mission planner and make sure you are using the latest mission planner stable release and upload firmware.
You can also manually download the version you want from the downloads.
More info here https://docs.cubepilot.org/user-guides/autopilot/the-cube-series-firmware-and-connection-troubleshooting
Any issues post back.
Thanks for the reply. So I am getting the Cube being recognized by my “Windows 10 Device Manager” as “COM 6 Cube Orange”. The issue is that when I try to connect it to update/flash the firmware using Mission Planner it does not connect to MP. Is there any settings or maybe another software i can use for the initial software install?
Since there is no firmware on the Cube there is no Mavlink connection to be made yet. Select the correct COM port in the drop down in the top right. Go to Setup>Install Firmware in Mission Planner and click on the firmware that you want to install. After that is done there should now be a firmware running on the Cube and clicking connect in the top right will start a Mavlink connection.
Check out docs.cubepilot.org for more details.
Also make sure you have the latest drivers on board too. Very important step.
Have smilar issue. Somehow shocking how nasty it is to get the cube orange connected to mission planner. You would hope it to be plug and play! Here is our issue:
We have windows 10 pro. We finally removed our mission planner and installed the latest Stable mission planner, Run it as admin, then opened Contr+ F screen to Clean Drivers
Downloaded driver.msi files as prescribed
Then reboot Mission Planner, connected the Cube orange and found this:
Com4 ProfiCNC CUBE – New c in the box of port options, but not the necessary one for the cube orange…
In device management same issue under port:
ProfiCNC CUBE - New driver required (COM4)
We followed instructions on this page and yet do not succeed…
How come we do not get the right drivers installed when downloading the driver.msi Hope for a swift solution! Cheers Winfried
