I am using the Yaapu Telemetry Converter Cable to connect Cube Orange Telem2 to the X8R S.Port. When I ‘Discover new sensors’ on my Xlite Pro radio I only get RSSI, RxBt, and GPS (GPS is the only new value).
Settings I use:
SERIAL2_BAUD == 57
SERIAL2_OPTIONS == 0,
SERIAL2_PROTOCOL == 10
RC_OPTIONS == 32
Do I need to change parameters on Ardupilot to enable the full stream of telemetry? Or do I need to modify the output signal for the Yapuu Converter cable, now that the firmware is newer than the version originally intended for converter cable?
Notes:
Yes, I have tried making a straight wire Tx/GND cable from Telem2. This yielded no telemetry at all using the settings SERIAL2_OPTIONS == 7,
SERIAL2_PROTOCOL == 10.
