Cube Orange, Mateksys 3901-L0X, optical flow sensor, indoor setup, AHRS: EK3 sources require visual odom
I followed this instruction and successfully completed the steps until the second flight test. However, for normal test setup, when I tried to change the setting:
  1. Set AHRS_EKF_TYPE = 3 to use EKF3
I encountered a warning message stating ‘AHRS requires visual odometry.’ Have I missed something? Thank you for your assistance!
I solved this problem.
Hi
Am having similar issues. May you share a dump file with me
I just wait a time and then it was disappeared. But I checked parameters again.
