I installed Cube Black FMU from mission planer. When I want to connect mission planner my cube connect. There is no problem.
But When I want to connect Qgroundcontrol, nothing happen. Qgroundcontrol software cant connect my cube black. What ıs the problem? Is it a driver problem?
Yes. Daily is normally only slightly less stable than the real Stable. That said we are in the process of wrapping up the next Stable which will be out shortly. So daily right now is about as close to a Stable as you get.
