I was purchased CUAV x7 pro using it on X8 octocopter .
The pmu which come with pack I had used and enabled battey monitor parameter like below.
Since manufacturer mentioned it’s CAN PMU so I have configured as below.
UAVCAN battery info
Power module : cuav HV PMU
Autopilot : CUAV v5 /or similiar ( I forgot exact mentioed over there).
Everything working well except the sensor not showing current consumption by the copter .voltage reading working perfectly can any one help me to work this .
Thank you.
