Hi, i am new to this
i have the CUAV P9 Radio and i have been trying to connect it to QGC but with no luck…
is there any steps that i can go though to make it work
Hello Yas,
First of all, try to be sure that these two things are correct:
Also, some QGC versions do not perform the autoconnect procedure correctly, so check if the MAVLINK port is identified in your device settings on windows and as soon as you identify the COM port of your radio, you can manually set the comm link at App Settings on QGC, providing the correct COM port and baud rate.
