Dear all,
I tried to use CUAV Nora, but I can’t set it up properly.
The figure shows the Servo Output screen of Mission Planner.
Only for the throttle, the output value is displayed as bar.
In this figure, I set servo 4 and 5 as RCIN6, and I confirmed that they worked, but trim and max/min value setting did not work.
Also I used “full parameter list” to set servo trim and max/min limit vale, but they did not work either.
On the other hand, in the Radio Calibration screen, the input for each RC channel is correctly displayed as a bar.
Now I have this situation with Plane-4.1.6 and Copter-4.1.3.
Please let me know if there is a way to fix this.
Thank you.
