CUAV Core X7 and NORA experience
It is the good one. You can have it with 6 connectors.
https://www.molex.com/molex/products/part-detail/crimp_housings/1511000006
Hi! Iā€™m working with X7 pro but Iā€™m not able to monitor the battery.
Do you know if I can adapt some of these values to my set up ? (10000mAh 12S battery and X7 pro, in addition Im using the PMU SE of CUAV connected to Power C port) .
I cannot find proper documentation about how to parametrize those values. Thanks
Hi @mlebret , @xfacta ,
I have problem about the Battery remaining Indicator (In percent) that shows very fast current consumption which is NOT consistent with ā€œbattery consumedā€ indicator on the same display. Any idea how to solve this problem? I have tried to increase the total battery capacity parameter, but problem still exist. Anybody could help how to solve this problem? Thank you.
I have created new thread about this Battery Indicator Problem here:
Use the initial parameters calculator to set the correct battery voltage-related parameters for a start.
two questions about the CUAV Nora:
  • what are the pins for BATT2? Is BATT2_VOLT_PIN=4 correct? What is the setting for the current?
  • it has been announced in one of the threads that Nora will finally get the UART3 (the one on the side) enabled. Iā€™m looking at the release notes and canā€™t see that this has happened. Any news?
  • BATT_V0LT_PIN=16
  • BATT_CURR_PIN=17
    nora supports only one analog power supply. UART3(Serial7) is already supported, please enable it in all parameters.
Thanks for your answer. I can confirm that the battery2 pins are working fine. Will check the UART3. Please update the docs:
https://ardupilot.org/copter/docs/common-cuav-nora-overview.html
including adding the detailed description of differences between Nora and Nora+, in particular if DSHOT telemetry is expected to work for the former one and for which outputs.
