CUAV Arduplane No pwm pulse in Main & aux for Throttle
Hi Team,
I tried using Arduplane firmware version 4.3.0 and 4.4.0 but there was no pwm output when the throttle was set in servo output. When I tried using firmware version 4.2.0 there was pwm output in servo output.
I tried using Cube Orange it works fine for all this firmware. This problem persists only in CUAV X7 PRO. Hope this problem can be solved soon. Thanks.
faced same issue on pixhawk 2.4.8
the servo output page of mission planner shows values in pins but no pwm signal is found at the pins, I checked using logic analyzer. All parameters were set correctly according to docs.
I even directly tried to map RCINx to a servo in the servo output page but still got no pwm signal.
make sure it is arming. the throttle will not output unless armed.
facing the same issue for X7+ Pro with arduplane 4.3 and 4.4
Hello @Kuldeep_Singh, welcome to the community,
The same problem has the same answer:
