During testing of my oktopter after setting the throttle notch filter I noticed that during flying circles with front of the copter set to the center of the circle I get critical messages by mavlink:
CRT EKF3 lane switch 2
WRN EKF primary changed 2
CRT EKF3 lane switch 1
Error pos vert variance
etc…
Generally that copter fly ok only during making circles that problem occurs. It appears in ALT-Hold and in Loiter but in Loiter after that messages bigger vibration occurs.
I changed BARO_PRIMARY to 1 and updated HERE2 GPS to CAN BUS and now copter fly ok without any errors but it looks like I have faulty BARO with baro glitches from time to time log from today
Is there possibility to completely disable selected Baro ?
Today I tested the same Cube Black with GPS ONE and the problem occur again. I don’t see Baro glitch in the logs. What can be the cause of lane switch 2,1,0 ? the log here second log
In different flight I triggered the problem when I started to climb rapidly. After message lane switch copter is vibrating more in loiter.
