Hi All
I currently have my Futaba transmitter to communicate via its receiver connected to a Pixhawk Cube Orange (RC IN) - this is obviously used for control and works well.
I also have a laptop running MissionPlanner connected via MAVlink (Bluetooth) to a TBS Crossfire transmitter that communicates via its receiver connected to the same Pixhawk Cube Orange (Telem 2) - this is used for telemetry data and also works well.
Now, to eliminate the RC receiver and increase the control range, I am trying to enable CRSF on the Futaba transmitter. This should allow me to send control data on the crossfire radio link and use the MAVlink connection to the Pixhawk.
The TBS Crossfire recognizes the Futaba transmitter as soon as it is physically connected to the RC Input port via a modified trainer cable supplied by TBS – FUT 12Ch.
https://drive.google.com/file/d/127HljWHCT2ezGa12bK2QzvK_AE0y2Die/view?usp=drive_link
Software versions:
MissionPlanner - v1.3.80
Futaba - v4.0A (Europe)
TBS Crossfire - v6.19
Pixhawk - v4.4.0
Configuration and Connectivity:
MissionPlanner
SERIAL2_BAUD = 115
SERIAL2_PROTOCOL = 2
Futaba T12K
LINKAGE_MENUE > SYSTEM > CRSF = ON
My understanding is that this setting enables CRSF on the trainer port and disables the internal transmitter. This is verified that connectivity to the RC receiver is lost at this point.
TBS Crossfire TX
No specific confiscation
TBS Crossfire RX
Mode = 12 Ch
Telemetry = ON
RC by MAVlink = OFF
Output 7 = MAVL.RX
Output 8 = MAVL.TX
With the above configuration, I am disconnected from the RC receiver immediately once I enable CRSF on the Futaba transmitter. Then, there is NO response in MissionPlanner when testing the RC transmitter controls. The same applies after rebooting the Cube.
Switching the TBS Crossfire RX, RC by MAVlink = ON, seems to send some RC control data across the TBS radio link but still does not allow me to use the controls. There is no response to any control input.
https://drive.google.com/file/d/12JFdzeHEp1BMFyrJbQbWrHaMMyilj-Sc/view?usp=drive_link
With this configuration, the four stick controls are fully deflected (all green), and channels 5 through 12 fluctuate between 50% to 100%.
I receive full telem data at all times.
How do I get this function working reliably?
LL
