Critical: PreArm: AHRS: waiting for home
Hi everyone! I couldn’t find a specific category for ArduSub, but I’m using ArduPilot for a submersible with a Pixhawk 2.4.8. I’m facing the error mentioned in the title. Does anyone know what I should change to fix this? I’ve already tried different configuration tweaks, but the issue persists. Any suggestions?
Hi @Narel,
I think the vehicle doesn’t have a GPS so it cannot get a position estimate and also can’t set the home location. I’m not a sub expert but I’m surprised that causes an arming failure in Manual mode. Maybe you’ve got some fences defined?
Thanks for the reply @rmackay9,
The pixhawk i am using doesn’t have external gps, even so, before this error does not appear. What kind of fences are you talking about? Could it be some configuration i turned on?
Hi @Narel,
Which version of sub are you using? When you say, “before this error does not happen” any idea what has changed? Firmware update?
Fences are enabled using the FENCE_ENABLE parameter
