If Aspect Ratio of Motor Positions
= Distance between lateral Front motors vs Distance between Front and Rear motors
= Lateral distance / Longitudinal distance,
for my best knowledge, aspect ratio of motor positions is ONE for the ideal configuration making a square.
However, we need a rectangle configuration having an aspect ratio of motor positions more than one due to a fixed wing geometry. That is, the lateral distance is longer than the longitudinal distance.
My questions are:
Can the QuadPlane support a longer lateral distance to have a value of 1.34 (134%)?
If yes, what parameter adjustments in Q mode are required for stable Q mode flght?
For a rectangular quad shape, what is the maximum ratio acceptable by the QuadPlane logics?
Many multirotor frames have that geometry w/o much consequence. “Squashed-X” or “Deadcat” are a couple. Slight reduced Pitch Authority is about the only issue and many may not even notice that. I would think that QuadPlane is analogous to this. I guess is could be more pronounced if the thrust/weight is relatively high compared to a multirotor which is common.
It will be clear after tuning. I had a couple of Deadcat like frames with one very distorted from an X and the Pitch and Roll parameters were quite different. But, proper tuning can handle that.
