Hello everyone I have 5010 motor i have 18inch prop too and I wanted to make nearlly 15min flight time how to calculate copter weight with battery and battery mah
Mine has 6s 340kv motor
payload is 5kg is it possible to make ?
By using eCalc.
Plz share your experience , i know there are so many ecals but I need practical knowledge
Thank you
There is no mentioning my motor brand name so I need guessing or need someone experience
Then use a T-motor 5008 340kv. It will be close enough.
I think you have all the info you need in the specs, but let me give you a walkthrough:
You said you have 18inch props.l & and you need more than 18 min flight time.
Usually we aim for at least 2x All up weight thrust
From the table we get that
@ 50% throttle with 1855 you get 1728gr thrust
Meaning 4 x 1728 = 6912gr total
So you aim for a 6912(or less) all up weight copter
Subtract the essentials
-170 x4 for motors = 680gr
-25-50gr x4 for ESC. = 100-200gr
= -1400gr
a. So if you had a 26Ah 6S battery you can provide power for an hour
b. With a 13Ah battery for 30min,
c. But you need to consider only 75-85 of nominal capacity thus you could aim for a popular 16Ah 6S battery
d. Most 16Ah 6S batteries weight about 2000gr
Happy flying,
That was life before ecalc, but these days we don’t really trust marketing tables, so give some headroom in your calcs, or try a thrust stand to make your one measurements.
Best,
Dimitris
