I am looking to modify the current existing loitering system for ArduBoat. I was wondering of anyone knows how uploading a customized firmware file into the mission planner could be done? We are currently using a CubePilot The Cube Orange Standard Set (ADS-B Carrier Board) with the latest version of mission planner. We are running an omnix platform as well.
Before building you’ll need to run “configure”. So for the CubeOrange, “./waf configure --board CubeOrange” or if you’re using the new CubeOrangePlus then “./waf configure --board CubeOrangePlus”.
You can also run, “./waf configure --help” to get a full list of boards available.
I am using a wsl for building and I run ./waf clean, ./waf configure --board CubeOrange, then ./waf and still get the same error. Is there something else that could be the problem?
I guess you’re quite new to programming which is fine of course, we all need to start somewhere … but I get the impression that maybe you’re not uploading the correct file but the details you’re providing are a bit sparse. Anyway, the ./waf step should product an .apj file in a build directory and this is the file that needs to be uploaded using MP.
