I have an FX-61 with HKPilot32 (GPS, airspeed, 3dr radio, power module, 4500 3s battery, etc.). I already assemby and test it in the manual mode (CG OK, elevon mix -TGY 9x, etc).
But, in the ground, when I try the FWBA mode, the ailerons are running too fast and sometimes giddily going up and down (they are in the main output 1/left 2/right. The trottle is in the 3).
@marcoafp,
Dataflash logs are the best when it comes to troubleshooting an issue.
You might try saving your full parameter list and attach the parameter text file to another post. Please do not paste the full parameter file into a post as it takes too much room.
I just calibrated my Anaconda pusher which is using a Pixhawk loaded with v 3.3.0 and I had no problem with it in FBWA other than I feel that the ruddervators did not move much when it was tilted back and forth in pitch. The ailerons looked good when I rolled it .
Regards,
TCIII GM
The problem stopped as soon as I installed the new firmware (I had to reset pixhawk before).
But, when I try to set the compass orientation to “Pixhawk/PX4” it always goes to “Manual”. Also I’m getting the message “Error compass variance” in the HUD. The compass is showing wrong rolling side, even when I change the roll angle in the Manual mode.
