Hi !
I was out flying my HK X650F quad yesterday.
First flight about 16 minutes without any problem, in Stablize, Alt-Hold and Loiter mode
Second flight, I run the Autotune, and after that normal fly in the three above modes, also without problem.
Third flight, everything worked perfect to the very end (14min). I was near my home point at an altitude of 3-4 meters, and I switched to Loiter from Alt-Hold. The quad than flipped over and down into the high grass field, so I only broke 2 props, no further damage.
Pixhawk with version 3.2-dev from 2014-04-26
I know, I should not run this, but because to get SBUS working from Futaba 7008SB I used it.
Short summary of hardware:
HK X650F quad
T-motor 2814/10 770kv with 12 inch Gemfan CF-prop
Maytech 40A SimonK ESC
1x 4S 8300mAh LIPO
3DR Pixhawk with 3DR uBlox GPS/Compass module
Futaba 7008SB RX with T14SG TX
Before the above flights, I have made all kind of calibration according to arducopter.com, and even the compass-mot calibration, and I did get about 25% of compass interference.
In an earlier flight I measured the vibrations, witch to me looks fine with AccX: +/-1 AccY: +/- 2 and AccZ around -10 . After that I turned off IMU-logging.
I think I will wait for en official 3.2 release before I fly this again, I saw that 3.2-rc1 is out now.
What could the cause be for this flip over, should I change something in my setup.
What should I log during future flights ?
I will attach the following log files:
[attachment=3]9.BIN[/attachment]
[attachment=2]10.BIN[/attachment]
[attachment=1]11.BIN[/attachment]
[attachment=0]12.BIN[/attachment]
When i look at the 12.BIN log at the point of flip over. I can see that ATT.Roll/Pitch go high and ATT.DesRoll/Pitch go high in the other direction. CTUN.ThrOut went high to 1000.
I hope someone could find something out of this logs.
Regards
//Stefan in Sweden
