Premier vol, premier crash kds 450 minipix, tube de queue tordue, deux servos hs,le rotor a démarré normalement et s’est emballé. Je ne trouve pas pourquoi ?
tlog
param
tlog
param
@alainlive I’m sorry to hear about your crash. Please post the log file off of the flight controller. That has the best information to be able to determine the cause of your crash. Thanks.
I noticed in your photos that the swashplate is a H3-120 reversed. Looking at the swashplate parameters, you have enabled the generic swashplate and you set your servo positions.
H_SW_H3_SV1_POS,-120
H_SW_H3_SV2_POS,120
H_SW_H3_SV3_POS,0
These servo positions are incorrect for your swashplate type.
Instead, you should have selected the H3-120 swashplate. You may have had to reverse the collective direction (H_SW_COL_DIR) to get the proper response.
I am fairly confident that this caused the crash.
Bill
Merci pour votre réponse, je vais regarder cela
