Hello everyone !
My Tarot 680 Pro equiped with Pixhawk 4.1.15 suddenly crashed while reaching a waypoint in AUTO mode.
The copter was loitering very good, extremly stable after installing an anti-vibration plate on the Pixhawk.
So I tried an auto mode mission, and in the middle of the mission, it suddenly started to do weird things in mid air while having no control.
I immediatly switched to AltHold mode, retracted the landing gear, and started an emergency manoeuver but my throttle was the only thing the copter wanted to respond to.
I suspect the GPS to fall of its mast, but the copter fell upside down so maybe it’s something else.
I tried to check the GPS values but nothing crazy, I just see the IMU going crazy, no error at that moment.
I managed to almost gently land the copter but it was not really controllable.
Here is the .bin file :
https://www.dropbox.com/s/dunql28hfaatnw6/crash.BIN?dl=1
There is no physical problem everything is in place exept GPS (pretty normal after falling on it …)
Also, the auto analysis mentioned that there is a high change in mag field but the GPS is litteraly 17 cm away from the board, mounted on a carbon mast …
[quote=“HugoPx, post:1, topic:83521, full:true”]
Hello everyone !
The copter was loitering very good, extremly stable after installing a vibration plate on the Pixhawk.
Compass = FAIL - Large change in mag_field (217.28%)
Max mag field length (1205.16) > recommended (550.00)
Regards
Hugo
