I just had a pretty bad crash with my quad. Its build with a Sky Hero Spyder and a Pixhawk (Arducopter 3.1) as a flight controller. I uploaded the last 30 seconds before the crash recorded by the GoPro.
[youtube]https://www.youtube.com/watch?v=xXa6YO1ShoI[/youtube]
The crash happened during a RTL triggered by a battery failsafe. It was only the second flight and the current sensor had not yet been calibrated, so the battery failsafe only relied on the battery voltage. In the attached logs the voltages seems to be at a ok level to be able to make it home. The quad really did not seem to just fall out of the sky, and actual roll and pitch seem to match desired roll and pitch.
Looking at the flight path on the map in mission planner I noticed that the home position seemed to be a about 70 meters away from the actual launch position. For reference I have also attached the previous flight where the home position is at the correct point. That is about where I launchd at the beginning of the second flight, too. The conclusion I have drawn is that the copter tried to return the the wrong home, wich would explain the strange flight path at the end.
I still am a bit confused though about the speed and the hight. To me it seems like the copter moved way to fast and a was loosing hight pretty fast.
The number of satellites and the hdop are at no point at levels which would explain the bad home position. So I am completely clueless what caused the hole mess.
Hopefully someone of you guys can help me figure this one out.
Thanks in advance
Gabriel
