Hi.
Could somebody help me analyze my plane log
This was the 10 time I flew this plane,
i was flight about 7 min in 500 radius
during the flight with no command the plane started to turn left in max rate , and get overspeed 31 m/s
and crashed nose down into the ground.
the plane is quad V-tail plane.
I’m afraid there’s a bug, because the incident took place after a few minutes with no command from the ground
I’m flying with the latest version 3.9.7
Where did the RCIN.C1…4 values come from in minute 4, while you turned in manual mode before switching to Guided-Mode ? If these are inputs from a Joystick, let’s take a look on the tlog-file.
