perhaps someone can help me discover the cause of a surprising crash my little quad (310mm) suffered today. It happened during autotune: the roll tuning was just over and the pitch tuning began when the quad suddenly lost control and fell to the ground.
I really have no idea what happened. After the crash, I noticed that the two “rear” motors don’t turn any more, but only shake and clatter. I don’t know, if this was a cause or a result of the crash. The log didn’t give me a clue. (Log attached: 03autotune-crash.bin.log)
A flight before the autotune session went absolutely ok. (Log attached: 02everything-ok.log)
Some facts / hints / questions:
Vibrations are ok (Log attached: 01VibsOK.bin)
It’s a fun quad therefore it as no GPS.
The compassmot result was quite bad because of the power board beneath the APM. But I don’t need the compass because I only fly in Stab, Acro and Alt Hold mode. So it doesn’t matter.
Before all that happened I had replaced the old SimonK ESCs with new, small KISS ESCs (18A). Could the KISS ESCs be the problem?
As power supply for the APM I use a 5V BEC. In the log I saw that Vcc varies between 4,92 and 5.07 volts. Is this a problem?
Motors: Flyduino X2208v2, 1100kV, Props: HQProp 8x5, Battery: 4S 2200mAh, Weight: 900g
All the best, Markus
