Yeah, there was no crash, I just wanted to check if log seems to be ok. Mainly ATT message since I did some tweaking of the parameters. I would lie if I say that I am fully satisfied with the parameters, it is still not as smooth as I would like it to be.
I did cut the throttle trying out to land on the first contact with the ground, but it turns out I need some more practice before I master this kind of landing hehe It turned out to be a bit rougher than I did expect.
Anyways, thank you Mike for having a look at the log!
I agree, however there are some problems concerning autotune with low KV motors leading to motor desync. And since the manufacturer of the copter we use had the exact the same problems I am hesitant about trying out the autotune.
@yansihua1096 for a start it is bad etiquette to cross post your request on many threads.
It is considered spamming, and you get very diluted replies rather than people being able to see the whole discussion in one thread.
The copter seems to also have a yaw oscillation that you should look into as well as my comments in the other reply on one of the other threads you posted to.
Check your Yaw filter settings.
