Hi Forum
Would really appreciate some help analyzing my latest crash. The quad seems to have lost power, causing it to descend and crash-land. I assumed it was a loose spinner again (despite my precautions), and the spinner on motor 3 was indeed loose when I found the quad. However, according to the log it is motor 2 that gets maxed out in the lead up and during the descent. Motor 2’s prop was tight.
Also, motor 3’s carbon prop had a chip out of the end, the only damage from the crash. Indicating that it hit the ground hard. If it had already been loose, this damage would surely not have happened.
I’m really confused. The only conclusion from the current state of the log is that motor 2’s power unit semi-failed. Causing it to lose enough power to descend the quad, but not a catastrophic failure of the kind that would flip the quad. The motor and ESC seem fine, and the quad flies fine in stabilize. Any feedback on what is going on here would really be appreciated.
BTW this is a 3DR PixHawk (3.1.5) based quad with HobbyWing (unflashed) 30A 6s ESCs, 380kV motors and it was flying with 12x38 SF Carbon props.
