Truth_T
(Truth)
February 19, 2024, 12:03pm
1
Hello.
I read through the ardupilot documentation about QRTL and RTL, but couldn’t understand many things.
first,
https://ardupilot.org/plane/docs/qrtl-mode.html
in this page says
" If a pure VTOL QRTL is desired, then you must disable the fixed wing RTL and approach feature by setting Q_OPTIONS bit 16."
I looked through Q_OPTIONS, and the bit 16 is “Always use FW spiral approach-always use Use a fixed wing spiral approach for VTOL landings”
the description is not the disabling fixed wing apparoach.
too many things is ambiguous in the documentation.
kd0aij
(Mark Whitehorn)
February 20, 2024, 2:31pm
2
That’s Q_OPTIONS bit 16 , not Q_OPTIONS = 16 (which would be bit 4)
Bit 16 has a value of 65,536 and the documentation for that bit is:
DisableApproach-disable use of approach and airbrake stages in VTOL landing
Truth_T
(Truth)
February 21, 2024, 4:23am
3
Thanks, because My english ability is not good,
I thought “DisableApproach” means “Disabling Airbrake”
You are reading plane documentations. For quad plane pure VTOL QRTL is not recommended, use hybrid RTL :- Return to Launch — Plane documentation
Truth_T
(Truth)
March 9, 2024, 1:20am
5
the documentation is about qrtl-mode / qoptions.
how can it be plane documentation?
