Currently we are developing the white label QGC application to customize our need. We could not open the White label QGC app when the the Baseline opensource QGC is running in Android.
As part of white label changes, We modified correct parameters in Qgroundcontrol.pro file such as QGC_APP_NAME, QGC_ORG_NAME ,QGC_ORG_DOMAIN,QGC_APP_DESCRIPTION
Even after changing, it does no allow the white label application to open when the the Baseline QGC is running in Android.
The white label QGC works well, when the open source QGC is not installed in Android.
We tried in both Baseline 4.2 and Master build and facing same problem
Kindly help here
