I think I have a corrupted data flash log. I’m getting an error (“ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection”) when I try to geotag my images in Mission Planner using this log, so I really need to try and fix it.
When I download the log from Pixhawk (running Copter 3.3) using mavlink in Mission Planner (v1.3.32) it is assigned a file name using the date and time of the download, not of the mission, which already indicates a problem I think.
When I review the log in Mission Planner the data/time column shows 0001-01-01 00:00:00.000 throughout. The same happens if I choose to review the mavlink downloaded BIN file in MP after it goes through the auto convert to LOG. And the same also with the BIN file copied directly from the SD card.
When I open the log in a script editor it appears to be OK with time values recorded for each data row but I don’t know well enough how to interpret these values to spot where it’s gone wrong.
Flash logs before and after this one have been fine.
The BIN file is too large to upload here (26 minute mission) so I’ve had to chop a bunch off the bottom of the file using a text editor in order to upload. So I hope that still leaves enough for the issue to be revealed. I’m imagining that the problem is somewhere near the top of the file.
Many thanks for any help.
Jeremy
