Thanks for checking. I think I can modify the weights of individual components and there is probably a ballast component I can add too.
It does seem less stable in qhover if I move the CG forward by 30mm
I can’t recall if you tried moving the CG back on the real model?
May be it’s the CG for Hover Mode. But I’m afraid this will not work in Plane Mode.
After a long time fighting with this Copter Tailsitter I will stop this project and go back to my Dual vectored Tailsitter to regain trust on VTOL Systems.
As retired we have a lot of time, but not for a long time.
Thanks for assisting my project.
Agreed, a lot of time, but probably not for long enough
Best to focus effort where it’s most likely to succeed.
Maybe I’ll try putting wings on this: Design and build of a coaxial drone
Wow! That’s exactly what I was thinking to ask.
Good luck! Keep us posted.
Im surprised you agree.
Yes, a new challenge, will follow you, thanks for the link.
Yes will post here, already started with an issue. It seems I attract issues.
Funny thing:
And have you seen, forward hover is produced by tilting the mots. Not by tilting the whole wing as a copter.
Also perfect hovering as 2 Mot Tailsitter.
Transition from tailsitter to normal VTOL looks crazy!
Thanks, I hadn’t seen that video yet, and I didn’t know the X450 had a tailsitter mode. Tridge tried that with his Convergence, but ran into trouble with the tilt servo linkages.
A tilt-tri with that tailsitter mode and a good thrust-to-weight ratio could climb much more quickly and efficiently than without it, although he doesn’t demonstrate it in this video.
Ï would be interrested in this forward Hover Mode. We have vectored Yaw and it should work the same way to get “vectored Forward”. The Roll with Throttle is good. Forward and “limited” Backwards would be great on the same way as Yaw and not with a additional Switch/Knob as already thought. Backwards would be also helpful to stop after Backtransition.
Hi all - really cool work in this thread. I am new to the scene and am exploring designs for a Copter Tailsitter and the most efficient route to flight.
Since I am new, please feel free to slap me around a little, especially when I ask silly questions. I’m drinking from the fire hose and need to find some focus.
First off my task list is to understand in broad strokes how to add a hex frame configuration to Copter Tailsitter. My goal is to explore control with no control surfaces; only torque and thrust control. To be clear, I will not be using rotating motor pods.
Can one of the forum elders help or point me in the right direction?
Q_FRAME_TYPE and Q_FRAME_CLASS to hex and x/+ or whatever. Q_TAILSIT_MOTMX some none zero value.
Currently the only way to do control surface free flight is to flash master/dev and setup the Q_ASSIST (82) RCx_OPTION and switch to force enable.
@robinasu Welcome to the ArduPilot forums!
You can use QACRO mode to explore the complete flight envelope of your copter tailsitter. Since it’s an acro mode, you can fly in any orientation with the copter controller using the motors for stabilization. Use QHOVER or QSTABILIZE as bail out modes. Be sure you have the CG right before you try fast forward flight.
When hovering, yaw control of my biwing was done with control surfaces and motors differential torque. I think about 90% of yaw authority came from control surfaces and the sum was good but not great.
A well known trick to improve yaw authority of a multicopter is to tilt permanently motors. This is something I have successfully tested on my biwing (about 10° inward). A good example is given by the amazon delivery drone (the hexa tailsitter one). Without control surfaces you will need more than 10° and small wing to be less sensitive to wind.
Guys, thank you for the tips!
From looking at the code it looks like QASSIST is used to supplement a non-tailsitter quad plane’s control surfaces and has some parameters to satisfy (angle deviation, etc) before QASSIST kicks in. My first thoughts are these activation parameters might need to be tightened up. Do you have any comments on this?
I am assuming the QACRO mode is used along with the Q_FRAME_TYPE, Q_FRAME_CLASS, Q_TAILSIT_MOTMX, and Q_ASSIST (82) RCx_OPTION. Is it that simple to get going using QASSIST?
The QASSIST and QACRO mode seem like a fast way to go to get started. From an architecture point of view, what would be the optimal solution? For example, with a hex multicopter tail-sitter not using rotating motor pods and Q_TAILSIT_MOTMX=0, why not send roll, pitch, yaw and thrust to some multi-copter mixing block? I am assuming this block could be APMotorsMulticopter, but I am not sure of the key differentiators between AP_MotorsMatrix, AP_MotorsMulticopter, AP_MotorsMatrixTS, and AP_MotorsTailsitter. My thinking is multicopter frame yaw maps to tail-sitter frame roll, multicopter pitch maps to tail-sitter pitch +90deg (depending on how you look at it), same for multicopter roll to tail sitter roll; may have the orientations off here.
To configure as a hex copter tailsitter, you need
Q_FRAME_TYPE = 2
Q_FRAME_TYPE = 0 for plus or 1 for X
Q_TAILSIT_MOTMX = 0x2F = 47 (must be nonzero for tailsitter behavior)
That will result in instantiation of AP_MotorsMatrixTS using the standard AP_MotorsMatrix control logic for a hexacopter, and all of the VTOL modes will use the copter controller.
Multicopter yaw does map to tailsitter body-frame roll, and pitch for tailsitters shifts by 90 degrees when switching between VTOL and FW modes.
Also look at Q_TAILSIT_INPUT: https://ardupilot.org/plane/docs/parameters.html#q-tailsit-input-tailsitter-input-type-bitmask
A value of 3 will result in the tailsitter responding to roll and pitch the same as an airplane would in both VTOL and FW modes.
Hi Mark, thanks for your comment. I spent some days getting familiar with QGS and the latest ArduPilot master download through QGC. I first set:
Q_FRAME_CLASS = 2 (Hex)
Q_FRAME_TYPE = 0 (plus)
Q_TAILSIT_MOTMX = 0x2F = 47 or 10111100
First, the bit mask 10111100 appears to be 5 motors. Do I not understand something? I tried 11111100 as well (motor 1 through 6 checked) and I could not get more than 5 motors spinning not matter how many motors I selected or which channels I connected the 6 ESCs. It also seems like the QGC check boxes 1, 2, 3 etc correspond to 8, 7, 6, etc; I couldn’t find any consistency so I must have a number of issues going on. It was late so could have been tired. I used arm/manual mode and throttle 100% with power cycling the battery to activate/calibrate the ESCs.
Did I miss a parameter setting or misunderstand you all? I would like to configure a hex tail-sitting multi-copter with only thrust attitude control - no control surfaces.
Sorry for the typo: the bit mask should have been 0x3F = 0011 1111 = 63 = 2^6-1
That represents all 6 motors with motor 1 being bit position 0 through motor 6 at bit position 5.
This mask specifies which motors are active in FW modes (so some of them shut down in FW flight). But they should all run in multicopter (VTOL) modes. You can use the MIssion Planner motor test function to verify that your ESCs and motors are working properly: https://ardupilot.org/copter/docs/connect-escs-and-motors.html?highlight=motor%20test#checking-the-motor-numbering-with-the-mission-planner-motor-test
Not a problem - I had a hunch you meant 0x3F but things aren’t working so I wanted to be sure. Initially, I tried to use the standard Mission Planner 2 download, but it wasn’t playing nice and would not load using OS X 10.15.5. I downloaded 2.0.27-rc1 and now MP2 loads, but the USB connection to my Pixhawk1 doesn’t work correctly. I removed the old FTDI driver and installed the Apple signed driver from the FTDI website- still nada. I also went back to the QGC and started over with fresh firmware.
Starting with a fresh flash of Plane “master,” only the Q_ASSIST option is available. Should Q_ASSIST be “enable” or “vtol_auto?” I have been using VTOL_AUTO. After I reboot the PIXHAWK, I can then see all the other “Q” options to configure the tail sitter. I set Q_FRAME_CLASS = 2 (Hex), Q_FRAME_TYPE = 0 (plus), and Q_TAILSIT_MOTMX = 0x3F = 63, ARMING_CHECK to nada, then reboot the pixhawk. My SimonK ESC’s are connected the to the Pixhawk main out’s #1-6. I then proceed to calibrate the ESCs and that’s when things get weird. I also removed the power pins from the ESC’s to disable the ESC BEC.
If all that sounds ok, I will dig into getting AP2 working and will try to mess with the ESC PWM calibration parameters. I guess I can dust off my Win10 image and parallels. What do you use to develop?
I don’t know what those Q_ASSIST options are; I don’t see them in the source code or the wiki.
I use mavproxy on the bench and it also has the motortest command implemented.
I also use QGC on an Android tablet at the field.
My last Apple computer was a Lisa 2
