Copter spins around. Log file analis Please
I’m new here and new to drones and ardupilot. Recently i bought an octrocopter made by rctimer with Pixhawk flight controler, and recent firmware. Its been third time i’ve been trying to take off the copter without any crash, with no luck unfortunately. I’ve been trying everything i could, ESC calibrations, GPS, COMPAS etc., even reset, erase Pixhawk EEPROM, no luck. Every time after take off copter starts to spining around and moves in a direction with all sticks cenetred, it feels like lack of control. i would appreciate any help, suggestions, log file analys.
Thank You
@azarath,
Here is an Auto Analysis of your dataflash log:
Size (kb) 1697.470703125
No of lines 23314
Duration 0:01:44
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (6.63%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.47, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = FAIL - 10 slow loop lines found, max 14.63% on line 705
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
Unfortunately nothing to be gleaned from the Auto Analysis.
You are going to have to review the dataflash log by hand.
Regards,
TCIII GM
I had a similar problem with mine. My radio was setup in heli mode instead of acro mode. Once I setup acro mode this spinning stopped.
Sent from my Nexus 6 using Tapatalk
